Page 4 of 113 FirstFirst 123456789101112131454104 ... LastLast
Results 31 to 40 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #31
    Oct 2006
    Las Vegas
    You list a use of this module could be for climate control. Here are a few insights. I'm sure digital outputs could be used as 'parallel buttons' on the stock control unit. Digital outputs could be used to drive solenoid valves on a vacuum system. Most systems have an analog controlled temperature control door (analog out?) and there are servo needs in many vehicles. Interfacing a stock unit would allow use of climate controls without the computer available, and then could provide input back to your board for 2 way communication and a good display for the PC. That would require some more inputs I believe (2way).
    It's been a while...
  2. #32
    Jul 2004
    Found the code for you . Sent it to your email address Nick.
    David
  3. #33
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by StealthRT View Post
    David
    Thankyou for the effort with finding that code, but it was way to complicated for the simple task. With the addition of 4-8 lines of code, it now has the option to run completely hidden in the system tray with a nifty little atom icon!
    To re-open double click. I do not plan on making the minimize to system tray a touchscreen enabled option. So it will be available as a command in the skin file called "#SYSTEMTRAY#" with the parameter of either "true" or "false". If true, then the program is minimized to the tray on startup and will remain there.
    1.9in x 2.9in -- 47mm x 73mm
  4. #34
    Mar 2005
    Quote Originally Posted by h3rk View Post
    Servo control, while pretty sweet, is not a top priority. It is however, on the horizon.
  5. #35
    Oct 2006
    Las Vegas
    Will a second brain work in the software with no problems? Will you need a second USB port available, or is there a header connection on the board for that as well as the output relay header?
  6. #36
    Mar 2006
    Right now the software supports 1 brain. But future releases of the software will allow up to 4 or 16 boards. It all has to do with how XP assigns USB devices and how our device ID's are setup. For testing 1 is easier to work out the bugs.
    But there will be support for more than 1 unit if the demand is there.
  7. #37
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    Quote Originally Posted by 2k1Toaster View Post
    Well we havent tried the application running under WINE. I don't see why it shouldn't work. It will be open source, so no active decompiler restrictions or anything. Right now the software is still in testing and developement as well, and when the first version is complete, it will be a free download on our "yet-to-be-determined" website.
    --Nick
    Awesome! sounds like a great start! hope i can help out at SOME point
    will the extra devices be offered from you guys as well?, ie accelerometer, compass? and what ever else
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  8. #38
    Mar 2005
    Quote Originally Posted by red_parchel View Post
    Yes.
  9. #39
    Oct 2006
    Las Vegas
    multi board demand >= 1 so far
  10. #40
    Mar 2006
    Ok. It is a good start!
    It really shouldn't be too hard, and it will be implemented in the future. For the beta stage though, it will be single board. By production time (pretty soon), we hope to have a stable multi-board support.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
