Page 40 of 113 FirstFirst ... 30313233343536373839404142434445464748495090 ... LastLast
Results 391 to 400 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #391
    Jul 2004
    Quote Originally Posted by Rowan View Post
    Here's a pretty sweet place to start with bluetooth:
    http://www.sparkfun.com/commerce/pro...roducts_id=582
    From PC it wouldn't be *too* hard..
    But, it would be extremely hard to have it controllable via phone... You'd have to write software for pretty much every different version and brand of phone..
    Nah, Java is compatible with all platforms.
    David
  2. #392
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by StealthRT View Post
    David
    Java along with C++ are the banes of my existance... So I wont be doing Java anytime soon unless my life depends on it...
    1.9in x 2.9in -- 47mm x 73mm
  3. #393
    Jul 2004
    Quote Originally Posted by 2k1Toaster View Post
    I may be able to help out with that side. I just need to see what u can do on the hardware side to get it working. If u can get it working Via .net, C# using the computer then im sure i can find someone to change it into java for us.
    David
  4. #394
    Low Bitrate Rowan's Avatar
    Aug 2005
    Melbourne, Australia
    Ok, well start here then .. :P
    http://www.sparkfun.com/commerce/pre...hp?p=The%20DIP
    but use this:
    http://www.sparkfun.com/commerce/pre...p=Blue%20SMiRF
    as it has 5v regulator onboard..
    Shouldn't be too hard to add, since the USB setup is CDC and basically imitates a serial link anyway...? Might be an option for an addon board.. as at $60USD/piece it basically doubles the cost for an option only a handful would use.. You'd then have (possibly) a jumper on board to select USB comms or Bluetooth, which would tell the 4550 to listen on its RX/TX line, or via USB...
    Holden VY Calais 5.7lt LS1 V8
    Computer:
    MB896 Pentium M Mini-ITX Motherboard, Intel Pentium M 750 1.86 GHz, 1Gb DDR2 Ram, 250GiB SATA, Xenarc 800TSV 8" VGA Monitor with touchscreen, GPS/Cellular/PCS/WiFi antenna, Bluetooth GPS, etc ,etc
  5. #395
    Jul 2004
    Come on and chime in Nick
    David
  6. #396
    Mar 2006
    Well the problem is that the PIC doesnt decide what happens to what output based on its inputs. It just sends what it gets to the PC, and the PC interprets it and shoves it back to the PIC with maybe altering a DO state. The brain by itself is "dumb" so to speak.
    With the bluetooth module, this would need to change because you effectively take all the processing on the PC and try to cram it onto a PIC...
    So basically not designed for that at all. Why not an el cheapo usb bluetooth dongle, and then the program PC side might be able to interface with that sort of thing? This would require it to still be PC dependand.
    If we move everything off to PIC processing, we wont be able to use the 4550 because it is simply not fast enough nor does it have the processing power.
  7. #397
    Aug 2005
    Its certanly fast enough.. it doesn't have all that much ram (32kB). You wouldn't need to get the PIC to do everything anyway, like i'm saying this Bluetooth device IS what you are imitating over USB anyway! (a serial link)
    Computer:
  8. #398
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    If they do go with bluetooth it will probably help me out a lot... Im having the hardest time dealing with StreetDeck and both my DLLs and the ones that have been provided for me. Even with the code and what not StreetDeck just refuses to work for me... Stupid VBScript. I don't know I think I'm just trying to hard to get it to work with StreetDeck, I should just go back to scrutinizing the hardware and software I got instead of making my own.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  9. #399
    Dec 2006
    MA, USA
    I hate Java but if it will help this out I will do it, same with C++ except I like it a lot more than Java. A good idea would be to offer bluetooth on a more expensive model without USB or something like that. If not I will try and hack it in if I could get more info on how the PIC communicates with the PC... Im tired so I think I'm just rambling on but I will be willing to do all of what I said.
  10. #400
    Mar 2005
    1. It is not fast enough. We are sampling at 1000hz and it cant handle much more.
    2. Shipping on orders over $50 is free and built in to PayPal.
    I think that's all the hardware questions, repost if I missed one.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
