Page 46 of 113 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #451
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by h3rk View Post
    Yes, lets, because no one has given me any info on the problem of the Fusion Brain not working through a USB hub. Has anyone tried this with a hub?
    BTW no more connect/disconnect problems
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  2. #452
    Oct 2004
    NY
    haven't tried it through a hub yet... that could limit how many of these can be used togeather I guess too, I'll try a few different hubs tommorow, maybe theres a hub that'll like these...
  3. #453
    Mar 2006
    Colorado, but Canadian!
    Ok people, get ready. Im just testing the last parts of this. I think it works... But I am too tired to figure out if it is buggy or not.
    Give me a few and ye shall have.
    1.9in x 2.9in -- 47mm x 73mm
  4. #454
    Mar 2005
    Quote Originally Posted by P3D4T0R View Post
    Through a hub works fine for me. It re-prompted me for drivers.
  5. #455
    Mar 2006
    Ok, right now when you start the program with no skin, you will get NOTHING. All and I mean ALL Buttons are now generated.
    The Configuration Pages are right now completely useless. So I took out the button, and there is no way to get to them right now.
    Here are at the moment all the skin commands that can be used at any time for each section except for the main area:
    Code:
    Digital Output Ports
    #STARTNEW#
      #NAME#
      #TYPE#
      #DEFAULTSTATE#
      #ANIMATION#
      #IMAGEON#
      #IMAGEOFF#
      #SIZE#
      #LOCATION#
      #LINK#
      #AUDIOFROMOFFTOON#
      #AUDIOFROMONTOOFF#
      #SHOWTEXT#
      #PAGE#
      #PORT#
      #VIDPID#
      #TXTCOLOURON#
      #TXTCOLOUROFF#
      #BORDERSIZE#
      #FONT#
      #TIMER#
    #ENDNEW#
    Analogue Input Ports
    #STARTNEW#
      #NAME#
      #TYPE#
      #SETTINGS#
      #VIDPID#
      #IMAGESTATIC#
      #SIZE#
      #LOCATION#
      #SHOWTEXT#
      #PAGE#
      #PORT#
      #TXTCOLOUR#
      #BORDERSIZE#
      #FONT#
      #PLOTLENGTH#
      #MULTILEVELGRAPHICS#
      #HIGHTHRESHHOLD#
      #LOWTHRESHHOLD#
      #HIGHKEYSEQUENCE#
      #HIGHMAINWINDOWTITLE#
      #HIGHSUBWINDOWTITLE#
      #HIGHMAINCLASS#
      #HIGHSUBCLASS#
      #LOWKEYSEQUENCE#
      #LOWMAINWINDOWTITLE#
      #LOWSUBWINDOWTITLE#
      #LOWMAINCLASS#
      #LOWSUBCLASS#
    #ENDNEW#
    Digital Input Ports
    #STARTNEW#
      #NAME#
      #KEYSEQUENCE#
      #MAINWINDOWTITLE#
      #SUBWINDOWTITLE#
      #MAINCLASS#
      #SUBCLASS#
      #PORT#
      #VIDPID#
    #ENDNEW#
    Other Buttons
    #STARTNEW#
      #NAME#
      #FUNCTION#
      #SETTINGS#
      #PAGE#
      #TXTCOLOUR#
      #IMAGESTATIC#
      #SECONDARYIMAGE#
      #BORDERSIZE#
      #FONT#
      #SIZE#
      #LOCATION#
      #SHOWTEXT#
    #ENDNEW#
  6. #456
    Dec 2006
    MA, USA
    Quote Originally Posted by greenman100 View Post
    What hub are you using? I assume your running Windows XP? did it prompt you the proper way? Mine prompted me with an unknown device and wouldn't accept the Fusion Brain drivers I tried giving it.
  7. #457
    Mar 2005
    Just a generic USB hub. I think it has to be USB 2.0. Is yours USB 2.0?
  8. #458
    Mar 2006
    The 5 areas are:
    >>MAIN
    <<END
    >>OUTPUTS
    <<END
    >>AI_INPUTS
    <<END
    >>DI_INPUTS
    <<END
    >>OTHERBUTTONS
    <<END
    To make a button you will need to put it within the needed brackets.
    Its starts with #STARTNEW# and ends with #ENDNEW#
    Then the factors inside are all the options for it. Some are required are some arent. Youll know which ones are required because it wont work or the program will crash.
    In order for the i/o buttons to work they need to know what port they are on. The Ports are 0 index based. And multiple buttons can be assigned to the same port. So on all pages you could have a button for "launch missles" but only on 1 page would there be a confirm or something.
    Now each i/o will also need a PID/VID. For all the ones that are currently out, use the string without quotes "vid_04d8&pid_000c" This is now what allows you to have multiple brains. Just assign different ports with dirrent pid's to different buttons.
    All the outputs need to have #TYPE# of RELAY right now. That is the only working one.
    if there is an animation, it must be #ANIMATION# and then the frames are between {} and the actual on/off states are 1 or 0 seperated by commas. Then 2 colons "::" and how many time to repeat. FOREVER or an integer value. Then the last one is the starting frame seperated by 2 colons again. 0 is what it should be left as.
  9. #459
    Dec 2006
    MA, USA
    Yes it is... I got it cheap and it doesn't even have a name on it so I guess I'm in the market for a new one, oh well...
  10. #460
    Mar 2006
    #TIMER# is how long in seconds after the PC is disconnected that the output keeps its state for before it turns off. Maximum of 63seconds.
    Now #LINK#... To enable the linking of outputs between multiple boards, the LINK number is based off of the order they are listed in this file. To make custom on/off in pairs or all or anything, just set #PORT# to -1 or leave the setting off. You must still count this though as a number in your list.
    So if you have
    btn1
    btn2
    turnon1and2
    bt3
    turnonall
    bt4
    and you want to link bt4 to bt1, the #LINK# for btn1 would look like this: #LINK#5 and the link for btn4 would be #LINK#0
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
