Page 48 of 113 FirstFirst ... 38394041424344454647484950515253545556575898 ... LastLast
Results 471 to 480 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #471
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by SmoL View Post
    can someone let me know how it goes with a powered usb hub Vs a non-powered usb hub??
    It shouldn't matter because the board is not powered off of the USB port it is powered purely off of its power plug.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  2. #472
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Great peace of hardware and software!! I found this thread last night and spent some time reading through the whole thing. I hope a I could help with the programing especially for the skins but my coding skills are not that polished yet!
    @P3D4T0R: I for one am very interested for the streetdeck interface!
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  3. #473
    Fusion Brain Creator
    Mar 2005
    remember guys, please put in your preorders now so we can gauge demand...
  4. #474
    Mar 2005
    NYC
    Isn't this device similiar to this?
    Here's the software too: SoftDash Software
    This guy seems to using his carpc and cell phone here:Project Gotham
  5. #475
    Newbie mp3gtr's Avatar
    Apr 2007
    Birmingham, UK
    Will you ship to the UK?
    If so then stick me down for
    1x Fusion Brain with DC Power Jack $50.00 USD
    1x Fusion Accelerometer $25.00 USD
    2x Fusion Thermometer Assembled $10.00 USD
    1x Fusion Relay Pack 4A Item #4A $22.00 USD
    Subtotal: $107.00 USD
  6. #476
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by DK888 View Post
    Sure it is similar. It has also been mentioned already. Here are some things to note:
    That thing costs $300
    It is over twice the size
    Uses serial port communication
    Has only 8 outputs and 1 input that must be used for tach
    Fusion Brain:
    Costs $50
    Is under 70mm on both sides
    Uses USB connction with no power draw from hub
    Has 12 digital outputs, 10 analogue inputs, and 4 digital inputs
    I believe I see a winner...
    Quote Originally Posted by mp3gtr View Post
    Yes we will ship to the EU, but you pay shipping and VAT. Please wait for a day or so and we will add a shipping upgrade button to te store. That way you can add the appropriate shipping. Right now shipping is free to the continental US with orders over $50 through USPS.
    1.9in x 2.9in -- 47mm x 73mm
  7. #477
    Oct 2006
    Las Vegas
    Quote Originally Posted by 2k1Toaster View Post
    The 5 areas are:
    >>MAIN
    <<END
    >>OUTPUTS
    <<END
    >>AI_INPUTS
    <<END
    >>DI_INPUTS
    <<END
    >>OTHERBUTTONS
    <<END
    To make a button you will need to put it within the needed brackets.
    Its starts with #STARTNEW# and ends with #ENDNEW#
    Then the factors inside are all the options for it. Some are required are some arent. Youll know which ones are required because it wont work or the program will crash.
    In order for the i/o buttons to work they need to know what port they are on. The Ports are 0 index based. And multiple buttons can be assigned to the same port. So on all pages you could have a button for "launch missles" but only on 1 page would there be a confirm or something.
    Now each i/o will also need a PID/VID. For all the ones that are currently out, use the string without quotes "vid_04d8&pid_000c" This is now what allows you to have multiple brains. Just assign different ports with dirrent pid's to different buttons.
    All the outputs need to have #TYPE# of RELAY right now. That is the only working one.
    if there is an animation, it must be #ANIMATION# and then the frames are between {} and the actual on/off states are 1 or 0 seperated by commas. Then 2 colons "::" and how many time to repeat. FOREVER or an integer value. Then the last one is the starting frame seperated by 2 colons again. 0 is what it should be left as.
    So let me see if I get this right, by changing vid_04d8&pid_000c to something like vid_04d8&pid_001c I could have two of these connected to two USB ports and access them both by referencing the right one in the skin file when needed?
    Great job with the software so far.
    It's been a while...
  8. #478
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by P3D4T0R View Post
    Still, the second part is still valid.
    On another note I was finally able to get StreetDeck to talk to a DLL I made so that headache is over only to bring on another one which I will post about later perhaps. Before I kill myself over this Id like to know how many people not only including beta testers would use with with there StreetDeck install, providing you have one or are going to at some point? I really just want to know if it is worth it... should I build one that I will like and will work for me or should I build one that everyone will enjoy, that's all I want to know.
    Finally I am finalizing my study of the program and will post all the cons I have found, and maybe some pros too, who knows :P
    Yea i am going to use it with SD, i plan to use it to be able to switch to back up camera and temp for now.
    i finally got a chance to play with it but i figure i will wait for the 2nd firmware version before i go any further.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  9. #479
    Mar 2005
    Quote Originally Posted by h3rk View Post
    Yes.
  10. #480
    Oct 2006
    Las Vegas
    Is there any way to have a button that could have control over another buttons 'enabled' property, like a pre-requisite? Seems the most likely way to do this now is with different pages that look alike, but have the required options "disabled".
    Can one output's state-change to on (or off) turn another one's state to off (or on) automatically?
    An example would be when you turn your highbeams on, headlights turn off.
    Like toggled radio buttons.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
