Page 55 of 113 FirstFirst ... 5454647484950515253545556575859606162636465105 ... LastLast
Results 541 to 550 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #541
    May 2007
    Will this work on old cars?
    Will this device read my fuel gauge, so i can get it on my carputer?
  2. #542
    Oct 2004
    NY
    yeap, no problem, it's just a range of resistance....
  3. #543
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Do you have the software available, so i could start skinning a screen to have it done by the time they come out? Can you run more that one board on the same computer? Thanks alot, Drew
    1998 Camaro Worklog Starting over, New setup for 2010
  4. #544
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by sporty_drew View Post
    The link to download the software was posted a couple pages back in this post.
    It has also been mentioned that you can hook up as many of these boards as you want in numerous posts.
    I know this stuff, as I read the entire thread a week or so back, before posting in it
    My Fiero Build Thread
  5. #545
    Mar 2006
    Iowa
    thanks alot, I've been watching it develop but have found it hard to read all the pages when it makes it's jumps
    It won't run, do i need the original software? and not just the update?
  6. #546
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    That I am honestly not sure about, I am not sure if it is completely hardware dependant to run, as I had the same problem trying to run it. I am just waiting for my board to get here
    Also, if you plan on running more than one board, let them know when you order the boards, as they have to make sure the have a different address from each other. Kinda like when ya were a kid and your friend and you got remote control cars for Christmas, and they were on the same fracking channel
  7. #547
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    It should run without the board I believe. You need to grab the mpusbapi.dll I think from the previously posted build. Is that the error your receiving?
  8. #548
    Mar 2006
    Iowa
    I've tried a few of the download links and all i can come up with is
    The application failed to initialize properly (0xc0000135). Click ok to terminate the application
  9. #549
    Mar 2006
    Colorado, but Canadian!
    That is the entire message? If there is a detail message, copy paste what is in there and go ahead and post that. It should reveal if it is an actual error in the coding, or just a compatability issue on your system. Do you have .NET 2.0 or beta 3.0 installed?
    1.9in x 2.9in -- 47mm x 73mm
  10. #550
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    you need to install the .NET runtimes; 2.0 or 3.0 will work.
    2.0: http://www.microsoft.com/downloads/d...displaylang=en
    3.0: http://www.microsoft.com/downloads/d...DisplayLang=en
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
