Page 56 of 113 FirstFirst ... 6464748495051525354555657585960616263646566106 ... LastLast
Results 551 to 560 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #551
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by P3D4T0R View Post
    you need to install the .NET runtimes; 2.0 or 3.0 will work.
    Is 3.0 out of beta yet?
    1.9in x 2.9in -- 47mm x 73mm
  2. #552
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I assume so since you can download the redistributable package and there is no mention of beta
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  3. #553
    Mar 2006
    hmmm. Learn new things every day.
  4. #554
    Dec 2006
    MA, USA
    BTW I got no real complaints for the program or the board, just one question... Are we going to get the final release of the board? You know send the beta ones back and get a nice new one with no problems, parts, or miss colored LEDs.
    The software looks good too although its been a ***** trying to replicate everything in VBScript but its working out OK I guess. Iv been meaning to shoot you two and email/PM iv just been really busy. I will tomorrow.
  5. #555
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Got it working thanks guys, one last question. what program do you make skins in? I've only made Roadrunner skins.
    1998 Camaro Worklog Starting over, New setup for 2010
  6. #556
    Oct 2004
    NY
    Quote Originally Posted by 2k1Toaster View Post
    Yes the PIC is like a CD-RW sort of. But like all CD's every now and then M$ effs up and you get a coaster. However usually this is total failure or total success. Rarely is it partial success and partial failure. So it should have either worked or didnt work at all, none of this sometimes crud. Maybe yours is magical?
    awe man, I guess mine isn't magical afterall last night I reopened the shop just to test this with the first pic, I did click several buttons several times, & I guess I just figured ahh, that's it, but tonight I spent a little more time with it & the problem is there sometimes with either pic..., SOOOOO it's not the pic
    tommorow I'm going to disconnect everything from the board & start from scratch, I'm thinking it might be possible that my 5v regulator may have something to do with it? don't know why it's only sometimes though, but I guess it's still a possibility...
  7. #557
    Oct 2004
    NY
    sportydrew, this is not like roadrunner in the sense that there is no program that will help you edit a skin like that, you basicly have to edit the skin file yourself in notepad or something
    heres some notes I took, this & opening the demo skin should get you started
    Attached Files Attached Files
  8. #558
    Mar 2006
    Iowa
    Quote Originally Posted by turbocad6 View Post
    great, i understand the way the coding goes just not how i can make it in notebook and save it at a SKIN file.
  9. #559
    Mar 2006
    Ah that sucks... I originally thought 5v regulator as well, but mine seems to be working alright. We asked for 1A regulators, and we got 350mA regulators... So it is quite possible that the pic is being underpowered I suppose, when the ULN2003's (flat chips by the led's 2 of them) kick in and the leds...
    The final version will have 1A regulators to solve this. Are you any good with soldering? At radioshack you can get a 7805 regulator looks exactly like what predator bought, and unsolder the regulator, and put the new on one. It wont fit in the same spot, it will stick up higher (probably and inch above the board with legs). Could potentially ruin the board, so dont do it unless you are confident. Also if you do it, make sure to take the PIC out of its socket.
    And I like how you compiled all the posts into 1 spot. Nice! Once I get the website finished it will be there too.
    I have some spare time tonight, and I am schooled out so I am working on the software section now.
  10. #560
    Mar 2006
    We definately appreciate all the wrok you have put into it.
    And as for the board. I dunno. Tim would know.
    And other than the regulator you soldered on, have there been other problems with your boards?
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
