Page 58 of 113 FirstFirst ... 8484950515253545556575859606162636465666768108 ... LastLast
Results 571 to 580 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #571
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by 2k1Toaster View Post
    hmm... that is odd. Well we might have 2 bad flashes then... I'll look into it more.
    Does it happen everytime that you reset the PIC, or every now and then?
    Every time... same lights, not all of them just those 7
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  2. #572
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by P3D4T0R View Post
    Ok, then that is not a problem, just the firmware update. I know on the board that Tim has (the latest version) never does this. So this is no longer a problem.
    1.9in x 2.9in -- 47mm x 73mm
  3. #573
    Oct 2004
    NY
    yeah, without the board or a schematic in front of me I made a bad assumption, I'll play with it tommorow...
  4. #574
    Mar 2006
    Quote Originally Posted by turbocad6 View Post
    I dont see the need for regulated output for the relays... It is just a coil of metal.
    Do you see any need for regulated output?
  5. #575
    Oct 2004
    NY
    no, not at all, I just assumed a 12v regulator cause if it had a 5v output then it woulda had a 5v regulator,.. didn't really think about it when I assumed 12v... for the way this is being used it's fine as is... anything else necissary for a particular aplication can be accomidated from there...
  6. #576
    Mar 2006
    Ok Software section is up and running. It is in no way complete, but the links for the newest software and skin is up.
    http://www.fusioncontrolcentre.com/software.html
  7. #577
    Dec 2006
    MA, USA
    Sorry guys but because of the recent changes in the program (more dynamic) I have to go back to the drawing board and redesign my program... so ill post something significant to do with this when I get a chance. In the mean time ill just help out directly with the hardware/software. Thanks for the encouragement and ill get this to you ASAP but for now I'm starting at square one :shrug: Ill get you StreetDeck guys what you want no worries.
  8. #578
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    I, as a SD guy , more than appreciate your work and I am in no particular rush to have the program, I just want it at some point so THANKS for all your great work!
    I wish I could help but my strength is in hardware and I am just taking my baby steps in coding...! I started from some C++ for now
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  9. #579
    Mar 2006
    Well the old version as it was released a couple weeks ago (last one) will still be available for download. It only supports 1 brain, but if your program needs it, then we will continue to host it.
    If you want to redesign it for he dynamic program, then maybe there is something I can add in there for you... Maybe a create hidden button command, or maybe change the name of the button to something, i dont know, just something that would help.
  10. #580
    Dec 2006
    MA, USA
    Im not sure exactly what I would need to help me with the program I'm trying to build but a COM visible DLL that can be registered using regsvr32, other than that I'm not sure I'm still trying to think about how I can do this...
    What I am trying to to do is replicate the functionality of Fusion Brain in StreetDeck minus skinning, button sounds, and pages; while adding the ability to use StreetDeck's stuff through the mod. For example have a DI detect when you are in reverse and call the back up camera or detect when u are in drive and call the nav interface, as well as other things. But making it selectable/customizable.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
