Page 61 of 113 FirstFirst ... 11515253545556575859606162636465666768697071111 ... LastLast
Results 601 to 610 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #601
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by turbocad6 View Post
    cool, thanks for the animated gif's,gonna play with this
    I think a g-meter is going to be all you can use there gtr, an angle meter would have to compare to absolute level & not the road anyway, I wouldn't think what your talking about can be done...
    Actually it can be done with EMF readers. Basically a 3d compass. As long as it is far enough away from metal, so put it in the cabin somewhere not hidden in the dash, it can sense direction in 3 axis's without the need for a reference because it measures the earth's magnetic field. They are pretty awesome, but that cool factor comes with a price. I am still looking though. The only downside is that in a few thousand years, it wont be accurate anymore, but I dont think your car, or even the USB standard for that matter will still be around then anyways!
    Oh, and your welcome.
    1.9in x 2.9in -- 47mm x 73mm
  2. #602
    Mar 2006
    I am not sure if anybody but myself is interested in this, but I made a primitive Speech Recognition for the software.
    It is also on the website's download center: http://www.fusioncontrolcentre.com/S...%20Install.zip
    You will need multiple files for this, so that is why it is not just an exe update.
    The Main FusionFormDynamic.skin has new areas:
    Code:
    #USESPEECHRECOGNITION#true|false
    #USESPEECHFULLDICTATION#true|false
    I reccommend these settings:
    #USESPEECHFULLDICTATION#false
    #USESPEECHRECOGNITION# -- if true, then speech is enabled, else it is disabled
    #USESPEECHFULLDICTATION# -- if this is set to true, then the entire dictation library is used, which can cause very frustrating results. If false, it will read and compile rules based off of the SpeechHierarchy.atom file.
    SpeechHierarchy.atom file is the first steps at a rule set.
    Code:
    #SYSNAME#Computer;
    #TURNON#turn on;activate;initialize
    #TURNOFF#turn off;deactivate;stand down
    #GENERALOUT#output;relay
    #AQUERY#what is;what's
    #GENERALIN#sensor
    #CUSTOM##OUT##0##ON#roll down windows
    #CUSTOM##OUT##1##OFF#roll up windows
    #CUSTOM##IN##0#what is the temperature;what is the current temperature; what's the the temperature; what's the current temperature
    SYSNAME is the name you address or commencing keywords. In this case I am testing so it is Star Trek like with "Computer" and also a blank is made by just adding a ";" with nothing after it. So If it was just "Computer" with no semicolon, then all the commands would be "Computer, blah blah blah". Just "blah blah blah" would do nothing.
    TURNON and TURNOFF are the keywords for turning on and off the digital outputs respectively.
    And GENERALOUT is what you call the outputs.
    Then the default is the port number as assigned in the FusionFormDynamic.skin file.
    So for example, to turn on Output 1, and then turn off Output 2, say the following:
    "Computer, turn on output 0" and then "Computer, deactivate relay 1".
    Of course "output" and "relay" can be interchanged as well as "turn on" and deactivate" can be switched to their other words such as:
    "Computer, initialize relay 0" and then "Computer, stand down output 1".
    Now, "#CUSTOM##OUT##1##OFF#roll up windows" will assign a custom command to the output at port # 1 to turn off when the phrase "roll up windows" is spoken. Pretty simple.
    "#CUSTOM##IN##0#what is the temperature" is pretty much the same as above with a custom message for the input at port #0 to read its value when the phrase "what is the temperature" is spoken.
    So go ahead and play with it. It is far from finished, but it works pretty well.
    And of course the dll from that new download must be in the directory as well.
  3. #603
    Oct 2004
    NY
    Quote Originally Posted by 2k1Toaster View Post
    yeah, but wouldn't that have to be 100% relative to level0% incline? how can the road be 100% level? wouldn't any pitch in the road skew these resulting readings to be meaningless as far as performance predictions etc?...
    I can see this being useful on an off road incline gauge, but wouldn't a g meter be better to predict & gauge performance related readings?
    sorry, back to topic, friggin voice control too!?!?!? that's so cool... this hardware/software is all that's needed to build KIT/nightrider type interface
  4. #604
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    What about "Fire photon torpedoes" ? when the idiot pulls out in front of ya.
    Yeah, that's the addition I was looking for. Something to rid the road of crazy drivers.
    Tennessee Vols Fan
  5. #605
    Mar 2006
    Quote Originally Posted by Volsfan View Post
    The voice file is user changeable.
    If you want all of them to respond to fire as turn on, then add it under the generalout, or if you just want it for 1 port, add it as a custom.
  6. #606
    Mar 2006
    Well the voice activation has a weird false positive on my laptop with no microphone at all plugged in.
    With nothing giving input to the mic channel, sometimes it recognizes "roll up windows" with supposedly great accuracy. Well, the good news is if I have a mic plugged in, it seems to work great.
    So moral of the story, dont enable speech, unless you are going to have a mic plugged in because it will start turning your outputs on and off whenever it feels like it.
    Anybody else get this?
  7. #607
    Jul 2005
    just letting evryone know, ive made leaps and bounds oin how to do my frontend.. and i can include many other things now i have the knowledge.. i hopefully can send and receive sms's straight from my software, using a specialised .dll. Zinc 2.5 is very very very powerful program to add to flash. i tell ya.
    awaiting your .dll toast. is it coded in c#? anychance of C++? or do they act the same in most circumstances
  8. #608
    Mar 2006
    Quote Originally Posted by Ryann View Post
    It will be coded in C# because C++ and Java are the bane of my existance. God damn pointers.
    But anyways, some pretty crappy luck has happened which included but is in no way limited to: lightning, smoke detectors going off, alarms systems that were installed before we bought the house but never activated so we have no code to shut the damn thing that is wired into the mains off, computer being melted, and cable modem fusing itself to the internet cable.
    So basically I have no internet, and I am forced to drive around lurking on unencrypted wifi networks at night time when everyone else is asleep.
    I am still having problems with the dll, and of course, all the help files all are the internet! I even had to call the cable company to send out a repairman to fix the internet, and lo and behold, I get on my laptop and google doesnt work. Its a natural impulse now!
    I am so glad we have satellite tv, or I think I would die from electronics deprevation.
    So I hope to get the dll out soon, but truthfully I am having a lot of problems getting the shared memory setup. Maybe someone can shed some light on this, but until they do, I will muddle through it and try my best. Wish me luck!
  9. #609
    Jul 2004
    I'll have a review soon. Been busy with my other 3 jobs so i havent even found the time to hook it up to the power (which i still need to buy a cable for...)
    But i did, however, get the new update chip.
    David
  10. #610
    Mar 2006
    Quote Originally Posted by StealthRT View Post
    David
    well keep us posted.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
