Page 66 of 113 FirstFirst ... 16565758596061626364656667686970717273747576 ... LastLast
Results 651 to 660 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #651
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by SKiTLz View Post
    Im looking at using a Temperature controlled relay so my CarPC wont turn on unloess its between a certain temperature..
    Can this Input/Output board combined with the temperature probe abailable do what ths device can do.
    http://www.process-controls.com/ener...ture_relay.htm
    That looks perfect. But your board may work also im just not sure on the functionality.
    Cheers
    This board is PC dependant. So the PC needs to be on the interpret the data. So it cannot be used to prevent the PC from turning on, but you could use it to prevent other things from turning on as long as the PC itself is on.
    1.9in x 2.9in -- 47mm x 73mm
  2. #652
    May 2006
    Calgary, Alberta
    Damn Toast, that should be on the main page. It just summed up this entire thread into one post and convinced me on a sale. I'm picking this up as soon as I get the cash. Is anyone making a Roadrunner skin with this incorporated or do you have to exit Roadrunner to control this?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #653
    Aug 2005
    Quote Originally Posted by 2k1Toaster View Post
    Yea makes sense.. I even knew it was PC dependant.. My bad.. Didn't think that through too well.. heh
    Well it will still work for my other things..
    Man my car is going to be a rolling electronics shop with all the wiring and PCB's..
  4. #654
    Mar 2006
    The entire purpose of the software I have been working on is that it easily embeds into any frontend, and is completely skinnable.
  5. #655
    May 2006
    Calgary, Alberta
    haha quoted the wrong post. But thanks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #656
    Mar 2005
    We got our supply of rotary and linear volume controls today, as well as our IR sensors.
    The linear volume control has an optional LED, in red or green.
    The IR sensor is good for 20-150cm.
    Any questions?
  7. #657
    Oct 2004
    NY
    ok, I've been crazy busy lately, but here is my review of the fusion brain:
    when I first saw the concept of this project I thought it was pretty cool, I mean it seemed very versitile & I had a few things that I wanted to try to computer control, I thank both tim & nick for allowing me to be a beta tester for this product.
    one of the apealing things of the fusion brain was the fact that the control software was skinable & was designed to be easy to embead in any front end, this was good. I had envisioned setting up the brain to control the remote starting of my car as a pc controlled device, & being able to control windows opening & closing, sliding door opening & closing & a few other misc controls, the fusion brain performed as promised, & I was very pleased to see no eronious or spuratic outputs, weather the computer was on or off or inbetween, through repeated power ups & downs, the brain never sent any commands by accident, which was one of my first tests.
    there was a small issue of a voltage regulator that was spec'd a bit low, but that's what beta testing is for, & the issue is being resolved on the production of these units, other than that & the beta boards having an error mix of red & green leds, electrically everything was fine, the board worked as it should & I was happy with the hardware.
    now the software on this fusion brain is where it get's interesting, I mean the software was cool,yeah skinable, but pretty static & not highly customisable, but I had envisioned being able to skin this in a way that was very dynamic
    I wanted to be able to display an image of my vehicle, & have it show the status of each of the items it had control over, similar to the display console of the new S-class benz. To my surprise, amazement & delight, nick also saw the benifit of this dynamic approach to skinning & software interface, & actually rewrote the entire interface making the whole program simply amazing, theres support for animated gifs, he even added the abilty to integrate gauges & indicators by using many different images that you put in file, it changes images based on values from another port, no flash necissary, it may seem intimidating, but if you can maniulate images & follow simple examples you can bud a skin for this.
    you can build a page & have controls & readouts any way you'd like to display it, you can put a link to another page that you can also build as a sub menu/display, this is as versitile & customisable as it gets short of writing your own program!! the software for this fusion brain allows you to build your own graphic interface with no programming knowledge required! the latest addition now is voice control... if they had these fusion brains back when micheal was driving kit they wouldn't have had to make that whole thing fake
    It's hard to really explain how thrilled I am with the whole concept of this fusion brain, suffice to say when pre orders were announced I ordered a few more of these, the uses of this are as wild as your imagination, I want to use these at home, in the car, I guess by now you can guess that I'm going to give this a rock solid 5 stars.... I'd recommend this to anyone who has a carpc or any pc that wants to control external devices & read external sensors, & then design there own skin to really have there own totally custom interface.... It don't get better than this & to me, there just is no competition
  8. #658
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    ^^ Great review, makes me really glad I've pre-ordered already. And one a side note, do we get to pick which style volume control we get with the pre-order?
  9. #659
    Mar 2005
    Quote Originally Posted by mezz64 View Post
    Default will be rotary, but if you want something different, email us.
  10. #660
    Mar 2006
    Thanks for the review turbo!
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
