Page 91 of 113 FirstFirst ... 4181828384858687888990919293949596979899100101 ... LastLast
Results 901 to 910 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #901
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Ryann View Post
    yea i tryed using the driver but it tells me there is no info in if that relates to the board and wont use it.
    Have you tried a good 'ol restart of your computer? Also make sure you have unzipped the driver file. When you download them they are compressed, and that wont work unless you unzip or unrar them.
    1.9in x 2.9in -- 47mm x 73mm
  2. #902
    Jul 2005
    when i power up.
    im aware its not detecting it, i just cant get it to use my drivers. im currently running power from a lil 9v battery, could this be why? i very much doubt it.?
    **** i just restarted, when i try and use that driver, it still tells me it doesnt contain information about my specified device. along them lines.. any ideas?
  3. #903
    Mar 2006
    Do you have another computer to try it on? Are you trying to install it through a hub? Is your computer USB 2.0 capable?
    And if your battery doesn't have enough juice, then yes it could be the problem. Also USB is very picky. If it is a real cheap battery or a battery that is not putting out 9v and closer to 7v or so, then that could be the problem. The board needs a minimum of 7v to function properly. If you battery is going between 9v and 6.9, it wont work.
    If you dont have a wall transformer for it, use the +12v line from your computer. (The yellow molex).
  4. #904
    Mar 2006
    Also pp3 batteries have extremely low mah ratings so a pp3 brand new will last a very very short time period.
  5. #905
    Jul 2005
    Quote Originally Posted by 2k1Toaster View Post
    well mine is USB2, its running straight into my pc USB2, and i do have another computer i can try it on tomoro,
    I connected power thru the 12v on the molex and im still geting the same business, ill try it on one of my other pcs tomoro.
    bummer
  6. #906
    Mar 2005
    bummer
    Hey, this problem is right up my alley, and I'm happy to help.
    The first thing I need you to do is take a screenshot like this for me:
    Like Nick said, we tested these all these before they went out - so it's most likely a configuration issue. We'll get it sorted out either way.
  7. #907
    Mar 2005
    I have fixed the issues regarding the Analog Inputs. All orders placed after July 1st will ship with this updated firmware.
    Email us if you would like to exchange PICs (the little processor on the board that contains the firmware).
    Thanks!
  8. #908
    Mar 2006
    Blog Entries
    1
    I'm looking for a solution to control a single relay by the press of a steering wheel button and I'm wondering if Fusion Brain will work for me. This is how my setup is configured:
    Steering wheel buttons hooked up to PAC-SWIX (converts button presses into infrared light).
    Igor USB infrared hardware then reads the infrared light and Girder 3.29 determines which button was pressed and sends the appropriate keyword commands to Road Runner (next song, previous song, mute, etc).
    This setup works beautifully and if an example Girder config file could be made to talk to the Fusion Control Center software then I'll definately go this route. I'm no expert at Girder and unsure if this will even work.
  9. #909
    Oct 2004
    NY
    The 2nd table down titled "Fusion Control Centre Skin Designer" with a version number of 0.1 is the newest version right now. Please give it a try, and tell me what you think.
    is that the newest or is it the other, the other looks newer & says it's an update????
  10. #910
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Geez...hadn't checked this thread in a while, but after going to the website...this thing looks incredible in terms of functionality for the dollar. You guys get my next $50 for sure!
    ...and nice review, Turbo.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 02:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 02:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
