Page 99 of 113 FirstFirst ... 498990919293949596979899100101102103104105106107108109 ... LastLast
Results 981 to 990 of 1124
Thread: *NEW* USB Input/Output Board -- Fusion Brain
  1. #981
    May 2006
    Calgary, Alberta
    I have some questions and couldn't take a week off work to read 66 pages.
    1. If I order just the board, will it be everything I need to hook it up to a fully working air ride suspension setup? Or are there some USB cables and stuff I have to order separately?
    2. Which gauge wire would I need to run to the battery for this? And will it draw any type of current when the car is off to kill the battery?
    3. How do I hook it to things like my windows? I mean without spoon feeding me, do I have to run wires to all the actuators or is there a simple way to plug it into the harness? Trunk release same way? Lights? Other things?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #982
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Maheriano View Post
    1.) If you order just the board, you just get the board. There are options to add USB cables and relays. I do not know the details of your air ride suspension setup, so I cannot answer questions about how to connect it.
    2.) 16gauge is fine.
    3.) The board will draw about 70mA with all the outputs off. If this is a concern, I would suggest connecting it to an accessory circuit. With relays on all the outputs, the board will draw about 2 amps. This is not significant enough to merit its own run to the battery.
    3.) Every vehicle's harness is different. Connection would vary from vehicle to vehicle.
  3. #983
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Greenman,
    No hurry, but did you get a chance to look into my missing USB cable? I just don't have any extras, so I can't use the board until i get one.
  4. #984
    Mar 2005
    Quote Originally Posted by Arrow View Post
    Greenman,
    Thanks for the reminder. I'll get one out today.
  5. #985
    Jul 2007
    Quote Originally Posted by 2k1Toaster View Post
    We have not actually made the 2-3 wire converter yet. It is really simple. We are going to try and get one done so it makes everything easier.
    So is there some simple circuit (amybe just a couple resistors or something) that we could build ourselves? Until you get the "professional" ones done?
  6. #986
    Mar 2005
    Quote Originally Posted by ginigma View Post
    Below are the specs on the 150psi pressure sensor:
    Code:
    150psi, 1/8-27 NPT
    PSI		R typical	R max		R min
    0		10		13		5
    14.5		31		35		27
    29		52		56		48
    43.5		70		74		66
    58		88		92		84
    72.5		106		111		101
    87		124		129		119
    101.5		140		150		130
    116		155		170		145
    130.5		170		185		155
    145		184		214		154
    Maximum 435 psi for 2 seconds only.
    Operating Temperature:  -13F - +212F (to +248F max. 1 hour) on
    connecting thread.
  7. #987
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Uh...no rush, but did my updated firmware get sent out yet ?? Just curious.
    PP sent on 7/18
    Thanks,
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #988
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Is there anyway to add hotkeys that can control outputs?
    1998 Camaro Worklog Starting over, New setup for 2010
  9. #989
    Mar 2005
    PP sent on 7/18
    Thanks,
    Sent it out yesterday. Shipments generally take 5-7 busness days to get out.
  10. #990
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by sporty_drew View Post
    Nope... But that is a pretty good idea. I will see what I can come up with. There are already quite a few keyloggers for debugging features, which might interfere, but since those features are "developed" I guess I can remove them now.
    I will add it to the list.
    1.9in x 2.9in -- 47mm x 73mm
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
