Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 98
Thread: Garmin Mobile PC
  1. #61
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I had GPS troubles when I positioned the receiver near my screen or near my computer. They can get interfered with by the electrical noise of different devices. Where did you reposition the GPS receiver?
    Want to:
  2. #62
    May 2008
    Its sitting on my rear Deck, next to my XM receiver and my BU-353.
    The PC is mounted under the rear deck in the trunk.
  3. #63
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have the same setup and the GPS won't lock. Temporarily put the GPS on the roof, away from the PC or move it somewhere else in the car and see if that does the trick.
    I have two options of where to put my GPS - on the dash or on the rear deck. On the deck, the PC interferes. On the dash, I can move the GPS way out to one side and it works okay. It works best on the roof, though. Locks instantly and never loses the signal.
    I've thought about building a metal 'shelf' that I can mount way up at the top of the hatchback glass. That would shield it from underneath and give an open view to the sky. I don't like the XM and GPS lumps on the roof.
    Want to:
  4. #64
    May 2008
    If you've moved it like that, you obviously have an extension USB cable, right?
    The 20x cable is only 1 meter long, so its hard to move it around without an extension.
    I'll try moving it to the other end of the rear deck. Its funny, because It worked great before I updated to the Oct 2008 patch, now it seems to be a let down.
    I guess I can mount it to the top of the glass in the back - I don't want anything outside of my car either.
    My buddy (who drives aggressive I will add) had his XM receiver cable that was mounted outside cut (he parked at a Metro station). I'm not sure if he ****ed someone off on the way, or it was just vandals, but I don't want to invite those issues, so no way I am mounting it outside.
  5. #65
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Minoritydan View Post
    I've used it on an extension cable before and I've also used it plugged into an unpowered hub and haven't had any problems other than the ones with location.
    Maybe the update is causing the PC to operate in a way that aggravates the interference issue.
    FYI - I also have a TomTom, which is practically brand new and had the same issue with it near the screen. However, if I got a lock on it and THEN put it near the screen, it would work fine.
    Maybe your almanac went out of date and it wasn't able to download it easily? Was it a long time since you used it?
    Want to:
  6. #66
    May 2008
    I used it on my trip from Baltimore up to Stowe, VT this past week. All the way there it worked flawlessly.
    I updated in Stowe (I had wireless, so I figured why not). Ever since then its been pretty poor in terms of performance, but it did lock on several times and have my correct location, but many times while driving Garmin would lose signal and have to keep recalculating, then it would show me way off course of the road that I was actually on.
    It just started behaving pretty odd.
  7. #67
    May 2008
    Well, I drove to the gym from work, and had no signal for 20 minutes, then at a red light I got full signal.
    When I left the Gym, I drove home and had no signal all the way, after I got home and parked, I had full signal - but I have no idea why its taking so long. I sat in the car for a couple min with Garmin loaded before I left the gym - hoping that being stationary would help, but it did not.
    Not sure what's going on...
  8. #68
    May 2008
    Now, mysteriously - Garmin is locking on in under 10 seconds.
    I get full signal pretty darn quick now, and I didn't do anything.
    Very strange!
  9. #69
    Sep 2008
    Western Australia
    I don't know what the hell is going on but Garmin Mobile PC won't load on any of my PCs. Vista and XP. Laptop and Desktop. No errors, just sits in the system tray loading nothing, sorta like it can't render the program :/
    Floppy drive is disabled in BIOS. DVD Drive is disabled too just in case. Still fails
    Edit: It has magically started to work now. Great software
  10. #70
    Dec 2008
    Does Garmin Mobile PC have functionality like the new Garmin ecoRoute™ plugin for nüvi® 205-series and nüvi® 705-series?
    http://www.garmin.com/garmin/cms/sit...vices/ecoRoute
    Save Gas and Money
    Now more than ever, we’re all looking for ways to conserve both money and fuel. Whether we’re taking fewer trips or carpooling with family and friends, saving resources is a top priority. It was that thinking that led to the creation of ecoRoute – our free software update for compatible nüvi products that allows users to find more fuel efficient routes when navigating and even track their fuel usage. With ecoRoute, you may be able to save gas and money by adopting smarter driving habits and finding more fuel-efficient routes.
    Select Fuel-efficient Routes
    With ecoRoute, users will have a “less fuel” option as a routing preference. When selected, nüvi will determine if more fuel efficient routes exist based upon road speed data and vehicle acceleration data for a given route.
    Get Fuel and Mileage Reports
    Through ecoRoute’s Fuel Report and Mileage Report, drivers can focus on their habits even when they’re not behind the wheel. Fuel Report tracks fuel usage over time, and Mileage Report monitors mileage and fuel usage on a per-trip basis. In addition, Mileage Report makes it easy for business travelers to keep track of distance traveled for company reimbursements. You'll have a detailed report for each trip and the miles driven. You can also customize your nüvi by entering your car’s fuel economy and the current price of gas.
Tags for this Thread
