Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 72
Thread: Garmin Mobile PC - No On-ScreenKeyboard????
  1. #31
    FLAC Marvin Hlavac's Avatar
    May 2005
    * I'm not clear on if it's possible to use different Garmin (or non-Garmin, but Garmin-compatible) maps with this product. I'm trying to find out.
    * I don't think Nuvi can output GPS signal via a cable, can it?
    * I'm looking forward to reading if you guys manage to embed Garmin Mobile PC into your front-ends. Hopefully it will work. I just quickly looked if I can control this program with AutoIt, but to my disappointment it seems it may not be easy - or not possible at all. But there may be other (better) ways to control the program.
  2. #32
    Apr 2008
    Do any of you route your audio via bluetooth to your cars head unit? Everything works for me excpet Garmin Mobile PC. For some reason it only is playing through the UMPC speakers. It baffles me because all windows audio is piped through the bluetooth connection when the link is present..(except GMP) ...Any suggestions?
    Steve
  3. #33
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Im test software embedded in Centrafuse and is not usefull...
    They are fix resolution and you can't change it...
  4. #34
    Oct 2005
    Try it with Full Screen mode of Centrafuse...hit the button between the keyboard and the X.
  5. #35
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by d0tech View Post
    Im try this first but is same sh**
  6. #36
    Oct 2005
    How did you get it to embedded into Centrafuse? It still open in full screen for me, its not embedded WITHIN centrafuse. It lays on top of Centrafuse.
  7. #37
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Im in settings add new application then setup application name, path and window name. Fullscreen you must have off...
  8. #38
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Anyone know how to use .img (Garmin maps)? where to place in the folder? got UK maps (which arnt available) im using UK maps from other version of Garmin (supposed to be compatible)?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  9. #39
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    .img map you must put in garmin mobile pc folder. You must unlock it for your "device id"...
  10. #40
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    yeah same question here
    so just dump them in the root directory for the program?
    eg c:\program files\garmin pc\
  1. Garmin Mobile PC
    By Bivio in forum GPS
    Last Post: 04-12-2008, 08:11 PM
