Results 1 to 10 of 11
Thread: Garmin Coordinates not normal
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Unhappy Garmin Coordinates not normal
    I noticed that the coordinates garmin allows are not allways the standard lat and long. It will not allow you to enter a coordinate with minutes large than 59. This sucks since alot of them go up to 99. It will bring you with in a few blocks, but really it could be better.
    Other than that, garmin is a far superior gps software to iguidance.
    New Age Garmin - Skin for RR
    Newbie thwack's Avatar
    Sep 2005
    Adelaide, SA
    ThunderStick,
    From what I can gather Garmin are using decimal Lat & Lon not minutes and seconds. So 54deg 59min might read closer to 54.97deg
    Have a look at this page and see if this will help:
    http://www.fcc.gov/mb/audio/bickel/DDDMMSS-decimal.html
    Have had an instance where a guy "lost" his broken down Ford F250 in the middle of the Desert because he had these confused was about 5Mi away from where his car was!
    If you can UTM is much more accurate because it is almost impossible to get this part wrong.
    Cheers,
    Thwack
    Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
    Car- 1988 Nissan Patrol 4WD
    Aug 2006
    West Allis, WI
    Thanks for the help... this is wierd minutes and seconds seems to be more of the standard with other GPS software anyway.
    Aug 2006
    West Allis, WI
    Is there a mathematical equation for converting between the two types of coordinates.
    Sep 2005
    Adelaide, SA
    Sure is, there are many ways apparently to do this conversion I have copied the following examples from http://www.csu.edu.au/australia/latlong/dms.html as this one was the simples to do by hand. there are programming examples at http://support.microsoft.com/kb/213449
    EXAMPLE1:
    D = Degrees
    M = Minutes
    S = Seconds
    .m = Decimal Minutes
    .s = Decimal Seconds
    DM.m = Degrees, Minutes, Decimal Minutes (eg. 45o22.6333)
    D.d = Degrees, Decimal Degrees (eg. 45.3772o)
    DMS = Degrees, Minutes, Seconds (eg. 45o22'38")
    Process for Converting Latitude/Longitude Coordinates:
    1) DMS --> DM.m (45o22'38" --> 45o22.6333)
    - Divide S by 60 to get .m (38/60=.6333)
    - Add .m to M to get M.m (22+.6333=22.6333)
    2) DM.m --> D.d (45o 22.6333 --> 45.3772)
    - Divide M.m by 60 to get .d (22.6333/60=.3772)
    - Add .d to D to get D.d (45+.3772=45.3772)
    3) D.d --> DM.m (45.3772 --> 45o22.6333)
    - Multiply .d by 60 to get M.m (.3772*60=22.6333)
    4) DM.m --> DMS (45o22.6333 --> 45o22'38")
    - Multiply .m by 60 to get S(.6333*60=38)
    EXAMPLE2:
    Converting Degrees, Minutes, Seconds to Decimal Format
    latitude and longitude in a decimal format: 42.1361
    latitude and longitude in degree, minute, second format: 42deg, 08min, 10sec
    To convert coordinates from degrees, minutes, seconds format to
    decimal format, use this easy formula:
    degrees + (minutes/60) + (seconds/3600)
    The example coordinate above would be calculated as:
    42 + (8/60) + (10/3600) = 42.1361
    or
    42 + (.1333) + (.0028) = 42.1361
    Aug 2006
    West Allis, WI
    Thanks for the help, this is going to be very very usefull.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by ThunderStick View Post
    That's a matter of opinion Thunder.
    To me it ain't all that!
    Aug 2006
    West Allis, WI
    Quote Originally Posted by treetop777 View Post
    Compared to IG 4, yeah garmin it is top notch. Tons more POI's, A lot more features, A lot better text to voice, Customizable vehicle icons... The list goes on.
    I hate to say it, but IG has a ferocious competition now.
    I my car anyway....
    Aug 2006
    West Allis, WI
    In RR I was able to knock out at least 3 screens in my skin because Garmin has those features native.
    Gas prices, Weather, Trip Meter, Hotel Prices, Flight Information.... You get the picture.
    Aug 2006
    West Allis, WI
    Oh yeah, nav by coordinates with out any hack needed.... THE BIG ONE
  1. Garmin Mobile PC
    By ptk in forum Garmin Mobile PC
    Last Post: 08-27-2009, 05:05 PM
  2. Replies: 16
    Last Post: 03-18-2009, 04:03 AM
  3. Garmin Coordinates No Good
    By ThunderStick in forum Road Runner
    Last Post: 09-06-2008, 08:17 PM
  4. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
