Results 1 to 10 of 10
Thread: Calculating routes takes way too long
    Low Bitrate AltimateX's Avatar
    Mar 2007
    Wisconsin
    I'm using 5.00.70 and I really like the software overall. It just takes so long to calculate routes. Even something that is 10 miles away takes a minute or more to calculate. This makes the program useless for me.
    When I first installed it, it seemed to calculate quickly but after installing this plugin: http://forums.fluxmedia.net/plugin-d...27-2010-a.html it now takes forever! Perhaps it is just a coincidence. I only tried calculating like one route before installing the plugin. I don't see why this should slow it down though. Its not just slow in CF but is slow even when just running GMPC by itself.
    This is under XP SP3.
    Any thing I can do to fix this? I'd really like to use this software but I can't afford the 1+ minute wait.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    If the plugin modifies core GMPC files (it used to-not sure if it still does), theres a pretty good chance its the cause. Routes usually don't take anywhere near that long even on very slow hardware.
    Mar 2006
    Colorado, but Canadian!
    what hardware are you running?
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Quote Originally Posted by AltimateX View Post
    If it were me, I'd uninstall that plugin and GMPC (possibly CF as well), then reinstall GMPC (and CF ). Likely the routes will calculate with better times, meaning the plugin was the problem. Which is usually the case when a plugin messes with the core operating files of the program.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    lol its got nothing to do with the plugin. It'd take 10 seconds to run GMPC in standalone and check that.
    What are the system specs
    Live mp3Car Facebook Chat
    Sep 2008
    Baton Rouge
    Interesting. I didnt think they made computers slower than my 2003 Vaio, which calculates routes in about 4 seconds, so unless he's running it on Pentium 3, it's certainly possible its the plugin which development seems to have dwindled. So I still vote to uninstall the plugin and GMPC, then reinstall GMPC. Im almost positive this will fix it.
    Validated by this statement:
    Mar 2007
    Wisconsin
    Sorry guys. I asked this question and never followed up after you guys were kind enough to try to help me.
    This is on a Fujitsu P1610 convertible. It has a 1.2GHz Intel Core Solo and 512MB Ram. I know its a little slow but when running the Garmin software I still have 175-200mb available ram and plenty of cpu headroom. My cpu usage is well below the 50% mark when trying to calculate the route and at times virtually no cpu activity is shown. So, I really don't think this is a processing issue. I just tried installing it with a fresh install of XP Pro SP3 (tablet edition) and it still takes forever. So even on a fresh install with no Centrafuse or the plugin, its still too slow.
    I tried running it on a more powerful machine under a virtual machine and had the same issue.
    Perhaps this is an intentional limitation of the demo?
    Sep 2008
    Baton Rouge
    So this is a demo version?
    Mar 2007
    Wisconsin
    Quote Originally Posted by ws6vert View Post
    Yeah, a 15 day trial if I remember correctly.
    Jun 2008
    Perth, Western Australia
    It is possible that the problem lies with the maps rather than the program.
    If the maps have any corruption in them, it breaks the way the software routes, causing dead ended nodes.
    I would definitely try what others were saying....uninstall GMPC, the maps and the plugin as a minimum, then reinstall just GMPC, test that on its on (Not in CF), then install the maps you require and test again, then install the plugin, and test again.
  1. How to Access Radio on Infill G4
    By devers6 in forum Software & Software Development
    Last Post: 10-14-2007, 12:52 PM
  2. Skin load time takes WAY to long
    By mygti02 in forum StreetDeck
    Last Post: 09-05-2007, 01:25 AM
  3. Replies: 13
    Last Post: 08-25-2007, 02:13 AM
  4. never lose focus
    By marsjell in forum Software & Software Development
    Last Post: 08-12-2002, 02:18 PM
  5. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 09:52 PM
