Results 1 to 8 of 8
Thread: Gps receiver for Garmin Mobile PC
    Jan 2013
    Dear all,
    Could you please tell me which GPS receiver is used for Garmin Mobile PC?
    I read the forum and just know Garmin GPS 10x and 20x used for GMPC.
    Can i use any Gps receiver for Garmin Mobile PC?
    I greatly appreciate your help
    Thanks,
    Quyen Tran
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Garmin had 2 versions of the software, 1 was with the included GPS dongle either 10x or 20x and only worked with the included dongle. The other version let you use any external GPS dongle. I beleive the any GPS version was called garmin XT. Hope this clarifies for you SNO
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Not quite - there is no difference between versions. Garmin just wanted you to think that.
    The only difference is in in the need for an unlock file when using ANY serial port GPS RX (Garmin PC in SW mode).
    You place the SW.UNL file in the Garmin directory and it will run in Software mode – Remove it and it will run in Hardware mode (Tied to a Garmin GPS RX) if the GARMIN.NVM file in the user directory is left there. (Back it up)
    You can delete the Directory in C:\Users\SomeName\AppData\Roaming\Garmin - BUT FIRST save the file GARMIN.NVM in the GarminMobilePC folder in the above Garmin directory. It holds the Hardwire REG Code for the X20 GPS-RX.
    Nothing else seems to be needed.
    Of course you need a way to generate the SW code if you have an existing Garmin (hardware) GPS setup. I'm sure someone can help out here - otherwise a search of Garmin GPS forums will turn up something.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Jan 2013
    Thanks so much for your reply. There was a youtube video that shows how to use generated sw code.
    http://m.youtube.com/watch?v=LzPuAiBipjQ
    However, i would like to know exact GPS receiver USB to buy as i don't have much money to buy a wrong receiver ( i am a student). Could you provide me the link of receiver i should buy?
    Many thanks,
    Quyen Tran
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    You do know that you can press the Satellite Signal ICON on the start window - click Disable if its still scanning or wait until the GPS can not be located message and after clicking the Signal icon you have the option of selecting a Bluetooth, USB or Serial GPS device. The USB ports will be displayed for selection.
    Any normal USB GPS mouse should work. Most GPS units run at 1Hz per second, Garmin can update at 5Hz per second if the GPS can output at that.
    I have used 5 different GPS units with Garmin, some $10 imports. BT‐Q818XT is a 1, 5, 10Hz unit that I'm running at 5Hz. Another I have is a TS-GUM004 or TSGEB004. Various USB GPS Dongles all worked.
    I'm sure others will post more, some are mentioned in the Garmin threads on here.
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    I been using this ------------> http://store.mp3car.com/New_BU_353_S..._p/gps-004.htm
    ........With iguidance, iGo8, and GMPC for some time now, and never had a problem.
    Nice unit.
    Nov 2009
    Keswick,On Canada
    I have bought and used the bu-353 and the bu-353-s4 but nothing beats this unit http://www.sureelectronics.net/goods.php?id=99 It has so many options to connect and external antenna SNO
    Jan 2013
    Thanks for all answers. I greatly appreciate your help.
    I setup Garmin Mobile PC successfully for my Car PC .
    Some pics attached.
    I would like to buy a 8" 16:9 capacitive touchscreen, but I couldn't find anywhere selling it. Therefore, I bought the restrictive touchscreen from mp3car store...
    Best,
    Quyen TranName:  2.jpg
Size:  119.5 KBName:  3.jpg
Size:  98.7 KBName:  4.jpg
Size:  154.8 KBName:  5.jpg
  1. Replies: 12
    Last Post: 12-31-2012, 03:48 PM
  2. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  3. HELP! Garmin Mobile PC GPS 20x USB receiver
    By lesterhung in forum GPS
    Last Post: 05-12-2008, 07:52 PM
  4. Replies: 3
    Last Post: 09-14-2006, 01:34 PM
  5. Garmin 35 PC USB VS. Deluo USB Receiver
    By SLAYER6669 in forum GPS
    Last Post: 10-03-2002, 01:33 AM
