Results 1 to 6 of 6
Thread: new to this... what is a dc-dc ?? dont understand, it is an inverter?
    Nov 2000
    Montreal, Canada
    Question new to this... what is a dc-dc ?? dont understand, it is an inverter?
    what is dc-dc? 120v to 120v?? i don't understand?
    Jul 1999
    West palm Beach , Fl, USA
    Post
    DC-DC lets you run your computer STRAIGHT off the cars 12v (in the US at least) electrical system. 120v interter first converts the 12v DC to ~120 AC . The computer PSU takes the 120 AC and makes it DC that the computer uses
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Post
    Inverter: Converts the 12VDC from your car's alternator/battery to standard 120VAC to run most appliances. Inverters are inefficient, noisy, large and can cause problems when used with certain PC power supplies.
    DC-DC Converter: Converts the 12VDC from your car's alternator/battery directly to the voltages required by the computer (12V, 5V, -12V, -5V). DC-DC is efficient, simple and produces no noise. It is the preferred way to go, but is usually more expensive than the inverter unless you build the DC-DC unit yourself.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Apr 2000
    Little Rock, Arkansas
    Post
    DC-DC just replaces your existing power supply in your computer. Therefore you would take out your current AC-DC power supply and put in the DC-DC power supply that you would buy/build.
    Grand aMP3
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    Nov 2000
    Beresford,NB,Canada
    Post
    Do you really have to put -12v on a AT mobo?
    If so, what is it for?
    Jan 2000
    Cool
    If you want to do it right, then yes. Some video and sound cards require it, and it is required by all serial ports. You will also need -5V.
    Aaron Cake
