Results 1 to 4 of 4
Thread: errr
    Low Bitrate jay_tu's Avatar
    Dec 2004
    Towson
    errr
    Hi,
    I have a shuttle PC ... AMD 2600
    Heres the problem... one day I stopped getting signal to the monitor (it gets power from the opus power was fine no video signal) ... but the light on the MB was on and it seemed to be booting up.
    After I took it in the house to run it on a Non OPUS PS... same thing.
    I took the battery out of the MB to reset the BIOS, after that it started up just fine ran for a few minutes ... I took it back to the car connected the OPUS it ran fine for about 15 minutes..
    The next time I tried starting it, about 20 sec's into booting it did the same thing... the monitor would blue screen like it was not getting a video signal...
    I took the battery out and put it back in. it worked for about a minute till windows booted then did the same thing....
    Any ideas ??? My systems was working fine untill this problem started.
    04 Corolla
    Modifications:
    Upgrading pc 99%
    Progress
    Mar 2006
    Colorado, but Canadian!
    refresh/resolution problem or it could be that you have the output set to tv out instead of crt/lcd out.
    1.9in x 2.9in -- 47mm x 73mm
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Get a new CMOS battery. I have that similar problem in my matrix setup. Try different combination and still does. Once time I look around the BIOS and notice the date isn't correct, I new it was the BIOS battery. Replace with another one form a "throw away" board, the system is fine since.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    Towson
    awesome, will try that.
    thanks
    04 Corolla
    Modifications:
    Upgrading pc 99%
    Progress
  1. Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
    By Mastero in forum Power Supplies
    Last Post: 09-25-2006, 11:15 PM
  2. laptop power supply question
    By ro8in in forum Power Supplies
    Last Post: 06-08-2006, 07:04 AM
  3. Basic, simple question from a Newbie...
    By dallaspunk in forum Newbie
    Last Post: 03-22-2005, 10:59 AM
  4. please help. need kenwood din pinout. will share project when done
    By hdd3md in forum General Hardware Discussion
    Last Post: 08-02-2003, 01:42 PM
