Results 1 to 5 of 5
Thread: USB hub not gettting 2.0
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    I ran a 16' usb active repeater cable (designed to carry power) to a basic usb hub in my dash. When I plug in my usb thumbdrive, Windows informs me that usb 2.0 isn't enabled. Do I need a powered hub to get 2.0 speeds at this distance?
    Mar 2006
    Colorado, but Canadian!
    no you shouldn't. But if it is a repeater cable, meaning a little box or buldge in the wire where it takes power and amplifies the USB signal, then that must be 2.0.
    USB only goes as fast as the slowest link in the chain. So if that cable only supports 1.1, and everything else is 2.0, you only get 1.1.
    Kind of a bummer. What cable do you have, and are you sure it is usb 2.0?
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    Everett, WA
    Yes I'm sure it's usb 2.0, and it has that bulge. The hub is an el cheapo "free with rebate" thing I got a long time ago. Do hubs have to be designed for 2.0?
    Yeah it's a bummer, my DVD drive reads realllly reeaaalllly slow.
    Mar 2006
    Quote Originally Posted by crooper View Post
    yes it must be designated as 2.0.
    As I said, it only goes as fast as the slowest part. Your hub is slow, therefore the entire thing is slow.
    Nov 2006
    Everett, WA
    Thanks, I'll find a faster one. I figured a hub was just a wire splitter.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. WTB: USB 2.0 external powered hub, Power wire
    By CavityCr33p in forum Classified Archive
    Last Post: 01-31-2006, 06:28 PM
  3. WTB: USB 2.0 Hub
    By Bailey in forum Classified Archive
    Last Post: 04-28-2005, 09:01 PM
  4. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 12:38 PM
  5. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 04:30 PM
