Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Random reboots.. whats going on?
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Recently my carPC has been suffering from random reboots (every couple of days).
    I will be driving along and all of a sudden I see the boot menu (Memory test, IDE info, and all that stuff you see when you first turn a computer on). It then will not boot into windows (fails soon after memory and IDE info appear) and continues to try to reboot a couple of times until it just stops outputting to my monitor. However, I hear the fan so the PC is still 'on'. So i unplug the pc to turn it off.
    I then let it sit a couple of days / weeks and will randomly plug it back in and it will work fine for a couple more days.
    I know I have not provided much info, but I have not investigated much. Currently everything from my wiring, to my psu, to my motherboard is suspect.
    Any suggestions on what is likely the issue?
    Thanks.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Heat issue, Power or a loose connection are what I would look at first.
    Is it about the same amount of time from a fresh boot for each instance?
    Yes may mean a heat issue.
    If it is over a bump is may be a loose connection of a data cable, power cable or the like.
    TruckinMP3
    Read the FAQ!
    Sep 2005
    Seattle, WA
    No the timing is not the same... Once I went almost a week until the issue struck again while driving on the highway...
    Another time I had drove about 20 minutes, went into the store (PC now on standby) and upon re-entering the car it would not power back up.
    I have my carPC power supply triggered by my car stereo's ACC line which I can toggle with the car stereo's on/off button... I toggled this button many times and the PC refused to power up
    B Smoov
    Jun 2002
    Colorado
    Right, Probably not temperature related then.
    Start looking for loose connections.
    Are you running windows? If so check the event viewer for messages that maybe related to the shutdown.
    TruckinMP3
    Read the FAQ!
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    This sounds alot like a hardware problem. Ive had similar problems and I know how frustrating it can be. Here are somethings you can try:
    1) emf. when my cables were arranged in a certain way, I would actually get so much emf that the screen would get all fuzzy and windows would crash within a few minutes. Rearrange cables (if you have a power cable, make it 90 degrees with any intersecting cables, if possible). My cables are wrapped in foil, and the foil grounded.
    2) A few months after, I had more stability problems, and the culprit turned out to be a failing CMOS battery.
    3)check your power. monitor the voltage and make sure its stable. Maybe try taking it indoors and see if it is working properly at home.
    4)remove some devices, like pci cards. maybe you have bad ram? bad capacitors(are they bulging)?
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    I am having similar problems but with a blue screen of death.. I'll be driving along and I'd get one... I've had 3 in the past 2 weeks.... recently it's been ok but I hope it's not an issue... :/
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Emo. check your ram. I have had this happen before due to ram chips either getting dirty or becoming loose.
    Apr 2005
    Washington
    Quote Originally Posted by buurin View Post
    Quote Originally Posted by Emo View Post
    Hope they survive burrin & Emo! I was not as lucky! I just posted long drawn out story about mines demise!
    Here if you got the time! http://www.mp3car.com/vbulletin/gene...long-post.html
    It seems many people are having same thing happen this spring. Could be just like a car getting oil leaks when things warm up! That is what I think my problem was, very long winter, and extreme fluctuations in temperature for 6 months.
    Anyway, I have been looking at more rugged systems like the MICROSPACE MPCX47 or MPCX48/48A to prevent happening next spring.
    Good Luck!
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    My CarPC did this kind of thing shortly before the hard drive died.
    Jun 2002
    Colorado
    I'd be 'VERY' surprised if the failures Tower Boss described are temp fluctuation related.
    Bad hardware is, well, bad hardware. Colorado has seen record lows in the last several months, additionally members are running set ups in much colder places than Colorado and Washington without the trouble he describes.
    Much more likely are poor connections and the occasional bad bit of hardware that would have the same issues on a desk.
    TruckinMP3
    Read the FAQ!
  1. Random Reboots - Anyone else?
    By chuckster in forum Road Runner
    Last Post: 12-08-2005, 11:47 PM
  2. Random...Little too Random
    By Prindle19 in forum Centrafuse
    Last Post: 01-17-2005, 06:30 PM
  3. ITPS + PW70A = Random Shutdowns / Reboots
    By tbird2340 in forum Power Supplies
    Last Post: 01-14-2005, 12:25 PM
  4. need second opinion on random reboots
    By netboy in forum General Hardware Discussion
    Last Post: 12-13-2004, 01:52 PM
  5. any problems with random reboots?
    By Squeezer in forum General Hardware Discussion
    Last Post: 07-12-2001, 08:59 AM
