Results 1 to 9 of 9
Thread: Intel 810 Book PC Display Setting Problem
    Jun 2002
    OKC, Oklahoma
    I have an Intel 810 Chipset Book PC running Windows XP and I dont have the option to set the display to anything less than 800 x 600 at 16 or 32 bit. Does anyone know how to change this to enable 640 x 480 mode?
    Thanks in Advance.
    OKC-X
    Mar 2002
    KY
    You can start computer in Safe mode and change resolution there. Remember, XP sucks at 640x480.
    Actually, just thought of this, you can try to switch to Win98 interface, it should look a little better than.
    Jun 2002
    OKC, Oklahoma
    Ok I will give it a shot. I figured I would have to have it at 640 x 480 to read the font on a 6.8" lcd. I dont have my lcd yet so I was trying to prepare things. Thanks for the help.
    OKC-X
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    You can fix this problem by going to this site
    I had the same problem and was able to fix it...
    http://www.microsoft.com/windowsxp/h...resolution.asp
    how are you powering you book PC? I seem to have a lot of system errors in starting windows... and it will restart over and over a few times untill it works, I also have a crazy mouse this happening...not sure how fix????
    BossTone74
    Jun 2002
    OKC, Oklahoma
    I am powering it with an inverter. I have had a few problems trying to run the computer with the car off and the inverter on. It doesnt want to start up at all. I start the car and the computer starts up just fine. I am actually thinking about buying the power supply discussed in this thread and getting rid of the inverter.Opus Power Supply
    May 2002
    Japan, Oregon
    I don't think the book pc is atx complient, and the opus powersupply is.... and atx power supply, it may work with some modifications.
    I want to continue using xp but if I keep having problems I'm going to 98, I have build two computers and one has 98, and I have never had a prob...I don't know why xp is being such a ******...
    BossTone74
    Jun 2002
    OKC, Oklahoma
    Thats right, I forgot about the funky bookpc power connector. I wonder if it could be modified.
    I havent had any stability issue with running xp prof. on the mine. Have you updated all the drivers and xp updates? Was it a clean install?
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    also, if you go to advanced on the video card properties, you can pick list all modes, and pick 640x480 32bit @ 60hz.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jun 2002
    OKC, Oklahoma
    MP3DUB,
    That's where I ended up finding it was under the advanced video card properties. I knew it had to be in there somewhere, I should of just asked here sooner instead of pulling my hair out trying to find it. Thanks to everyone for the help.
    OKC-X
