Results 1 to 8 of 8
Thread: SATA or ATA100
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    SATA or ATA100
    can i use a ATA100 in this set up? http://www.short-circuit.com/categories/carpc.html i found a great deal on a drive but not sure if i can use it...
    '08 VW Rabbit S 2.5
    Carputer Progress:
    Design:[][][][][][][][][][][][][][][][][][] 100%
    Fabrication:[][][][][][][][][][][][][][][][][][]100%
    Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
    In trouble...
    Feb 2006
    No. Your MB takes EIDE (IDE) and not SATA.
    I believe ATA100 is the same as IDE. SATA is the new standard with ribbon cables that are only 1 cm (or so) wide.
    IDE aka PATA.
    Mar 2006
    Colorado, but Canadian!
    Anyways, IDE is better for the car. Nice big connector.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Ottawa, ON
    If you use the Voom PC case that comes with that set I believe you can only use a notebook hdd. otherwise you'll have to mound the standard size drive outside the case.
    - Tam -
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    but if you're ok with pluging it OUTSIDE, most of the boards on those kits ALSO offer SATA connectors -- all except the MII 1200 (second one from the left). Check out the MB descriptions, it's all there.
    Ride Runner RR's Myspace
    Jan 2007
    Quote Originally Posted by EricE View Post
    IDE aka PATA.
    wait, its a 2.5 ATA100 drive. I can or cannot use it with that motherboard?
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
    May 2006
    Ottawa, ON
    If it's a 2.5 cm drive you can use it, but you'll need to get one of those 40 to 44 pin cables since you'll be connecting a notebook drive to standard IDE. Other than that you should be fine.
    - Tam -
    Jan 2007
    thanks....!
    '08 VW Rabbit S 2.5
    Carputer Progress:
    In trouble...
  1. Biostar M7NCG 400 v7.2 with SATA PCI Controller Card
    By msjonker in forum General Hardware Discussion
    Last Post: 08-31-2006, 07:54 AM
  2. Sata drive problems
    By EtoS in forum General Hardware Discussion
    Last Post: 07-28-2006, 03:23 PM
  3. SP1300 running SATA HD
    By skygtr in forum Newbie
    Last Post: 06-06-2006, 05:13 PM
  4. Replies: 16
    Last Post: 03-02-2006, 10:05 PM
  5. Replies: 2
    Last Post: 07-19-2004, 12:25 PM
