Results 1 to 3 of 3
Thread: Grounding question
    May 2005
    Grounding question
    Ok, I am an electrical newb but here goes.
    There is continuity between my -5v on my motherboard and the ground (as tested at the outer shell of the VGA connector) and there is also continuity between the -12v on my Xenarc screen and the outer shell on the VGA connector.
    My question is will there be a problem when a +5 and a +12 v line share the same ground?
    Is there a general rule of thumb I should be following for this kinda stuff?
    Thanks!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Newer mobo doesn't use -5V. -5V only use on ISA card, and if your mobo has ISA slot, there is problem (I think).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2005
    Quote Originally Posted by MatrixPC View Post
    I have a Single Board Computer that runs on 5V.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
  3. relay grounding question
    By mushrew0 in forum Power Supplies
    Last Post: 07-04-2005, 12:02 AM
  4. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  5. newb grounding question...
    By bstanton in forum General Hardware Discussion
    Last Post: 01-15-2003, 02:02 PM
