Results 1 to 5 of 5
Thread: Mouse Keeps clicking....
    Apr 2005
    Queens, New York
    Well I have always noticed that if i het a bumb in the road the mouse will "click". Like if i am in ig screen and it the mouse is hovering the menu button and when i hit a button it would click and open the menu. But NOW for some reason the mouse click are going really crazy.... Only when i am driving, the mouse keeps clicking. When i slow down to a stop then it finally stops clicking... ITs really annoying. I have to keep my mouse curson in the corner of the screen where their is no buttons to click or menus to pop up when clicked. Any1 have this problem?
    I have a Xenarc 700TSV if that helps...
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Feb 2006
    Vancouver, BC
    what are you using for a mouse? maybe contain that a little bit better. You could also fore go having a mouse icon. That could work if you use the touchscreen for the most part.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    He's using the touchscreen as a mouse. My only thought is recalibrating the screen. Sounds like it's taking the jolts as inputs... like maybe the pressure sensitive layer is moving? Weird.
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    It was happening to me before; My problem was that the screen wa being held too tight by the edges on the bezel I created. Loosened the brackets on the back and that fixed the issue. Also, if you took the screen apart and re-assembled it, make sure that the screws are not too tight.
    Apr 2005
    Queens, New York
    Quote Originally Posted by Maddominican View Post
    Hey i will have to try that thanks! Also i will try re calibrating the screen
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Replies: 5
    Last Post: 06-28-2006, 10:01 AM
  2. Conflict: Mouse vs. Touch Screen
    By fireball106 in forum Input Devices
    Last Post: 10-20-2005, 03:28 PM
  3. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 09:43 PM
  4. Replies: 4
    Last Post: 02-15-2005, 07:13 AM
  5. Smallest Touch PAd Mouse... or Shuttle Mouse QUESTION!!!
    By Boozshey in forum General Hardware Discussion
    Last Post: 01-23-2005, 02:38 AM
