Results 1 to 6 of 6
Thread: Screen input stops working after engine crank
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Sometimes if I load the computer with the engine off, and then start my car, the touchscreen input doesn't work anymore. The computer works, and the music keeps playing, but it seems that maybe the usb input isn't working. Restarting the computer fixes it, but that's annoying.
    Anybody have experience with this?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    it is probably a lw voltage in the power that powers the USB hub..it loses voltage and that makes it act weird
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    I havent seen that problem, do you have it in a hub, have you tried taking it out of a hub?
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Nov 2006
    Everett, WA
    It's in a non powered hub. It started doing this somewhat recently, but I've done some wiring changes lately. Maybe a usb plug is loose, but still I would think that would affect other things. Another thing that happens rarely (twice now in the past 2 weeks or so) is that sometimes upon reawakening from hibernation the screen's calibration gets reversed. A reboot fixes this too, but it has to be a hard reboot since I can't figure out where to touch.
    Apr 2006
    Greece
    ok if it is a non powered hub then maybe there is a voltage drop at your battery at crank, and the m2-atx can not handle it so i guess it is either your battery is getting older or even maybe it is interferance in the usb cable..
    Nov 2006
    Everett, WA
    Yeah I have killed my battery a few times lately running the CarPC without the engine on (seems to take less and less time). I suppose it might be time for a better battery. Thanks for the input.
  1. Replies: 14
    Last Post: 12-09-2005, 03:03 PM
  2. Touch Screen Stops Resonding after Calibration
    By Bigassbike in forum LCD/Display
    Last Post: 11-04-2004, 01:45 AM
  3. Xenarc touch screen stops responding
    By XxAndyxX in forum LCD/Display
    Last Post: 07-28-2004, 09:20 PM
  4. lcd screen with vga input
    By zx3chris in forum LCD/Display
    Last Post: 09-24-2002, 10:42 AM
  5. 6.4 " non working screen
    By prado_sergio in forum General Hardware Discussion
    Last Post: 01-17-2000, 06:36 PM
