Results 1 to 8 of 8
Thread: powered hub "freaking out" the 'puter?
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Got a funny problem and I'm looking for a little advice on how to handle it.
    First off, I'm using a dell optiplex gx270. I've got a powered hub in the front dash (running off a small 1000ma power supply, basically an ipod usb car charger) for the for the dash mounted dvd drive.
    Here's the problem:
    When I start the car, it seems power is feeding back through the hub to the puter and it looks as if the puter is going into a "hibernation" state (power button pulses orange). When I get the main power up and running (ie: car started or into acc), I have to shut the computer down by holding the power button for 5 secs and then everything will start as normal.
    If I unplug the hub, everything works fine. I've noticed that if I "unplug" the puters main power, my radioshark is still lit up and seems as if I am drawing power from the front hub through the puter usb ports and back out to the radioshark.
    Sorry if the description is a little confusing, but this is baffleing me a bit.
    Anyone have any idea what's happening here and what to do about it?
    Is there a "power on with usb" setting I'm missing or something similar?
    Cheers
    BJ
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Sounds like there may be some ground difference problems. Are you sure your PSU for PC and 1000ma PSU use the same ground?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Oct 2005
    Hmmm......
    The 1000ma uses a chassis ground under the dash, and the puter uses a chassis ground in the trunk.......
    I'll have a look at the dash ground again as I reused the old radio's ground, that may possibly be my issue.
    Cheers
    BJ
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The hub shouldn't be allowing the external power to be feeding back through the USB cable. You should check to see if that is what's happening.
    Feb 2006
    Vancouver, BC
    can the power for the USB hub be supplied by the computer's PSU? That way when the comp is off so is the usb.
    Oct 2005
    Quote Originally Posted by guizai View Post
    There's a thought.
    Although, I put the power source up front to power the hub due to power drop off on the long usb run to the DVD/cdrw.
    maybe if I used a larger gage wire than the tny usb power wire the power wouldn't drop off so much....
    Cheers
    BJ
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Modify the USB cable to the hub: Only use 2 data wire. No need for the power wire when the hub already has it own power. And modify the circuit that provide power to the regulator for the hub.
    I think the problem is when/during the car cranking, the regulator doesn't get power, and that force the hub to use the bus power. Switching from 1 source to another can cause the panic hitcup.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2005
    Quote Originally Posted by MatrixPC View Post
    I was thinking about doing that as well. I wanted to get a few opinions first as I'm not very experienced with this type of modification. It seemed logical to me though. Power feeding back through the wire, cut the source. Check.
    Thanks for the suggestion. Makes sense to me!
    I'll mod the wiring tomorrow and hopefully that fixes the prob.
    I was also considering adding a diode to prevent power feeding back through the usb. Same effect as cutting the power wire I guess.
    cheers
    BJ
  1. PCI Card VS Powered Hub.
    By SKiTLz in forum General Hardware Discussion
    Last Post: 02-07-2007, 07:44 PM
  2. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-14-2006, 11:00 PM
  3. Powered USB Hub
    By Belgiebob in forum Power Supplies
    Last Post: 01-08-2006, 09:53 AM
  4. Is DC powered USB hub good idea?
    By civic5zigen in forum Power Supplies
    Last Post: 10-21-2005, 05:29 PM
  5. USB Hub - Powered or non powered?
    By J187 in forum General Hardware Discussion
    Last Post: 07-06-2005, 03:24 PM
