8 ohms is ALOT. Plus you should have pretty even resistance with all the lines. I'm assuming that you used all seperate strand 22 gauge wire. Sounds like you may have a cold soldered joint. Find the high resistance lines and re-solder them and see if you can get a better connection.
Depending on the length of the run, why didn't you use ribbon cable or even a hacked and slashed printer cable? Sounds like you may have to re-wire the whole job...
either that or you cooked your LCD. Hey anything is possible.
LinkBack URL
About LinkBacks
