Results 1 to 9 of 9
Thread: Easily adapted UPS PSU for auto applications
    Jul 2001
    London
    Post Easily adapted UPS PSU for auto applications
    After spending months looking for a suitable solution to power my beast and finally settling for an inverter, I find this ups/psu which with v little effort could have done the job in a single package.
    check it out (about half way down the page)
    http://www.bullnet.co.uk/shops/test/batterie.htm
    conditioning and all the tap you need for 29
    Twin
    Aug 1999
    Upper Marlboro, MD 20772
    Red face
    ooouuucchhhh...look at the size of that thing...ouch!
    abcd-1
    Jan 2001
    Adelaide, SA, Australia
    Post
    yes it is very large! but would it work? by running power from the cars battery to the internal batteries, could that be used as a dc-dc psu? along with aux battery? or even ditching the internal batteries, and running that off the main battery?
    any ideas?? comments?
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    I'd loose the internal batteries and connect the car battery instead. Sounds like a good idea for a cheap DC-DC.
    Jul 2001
    West Chicago, IL
    Post
    It could work, but maybe not. I've tried the same thing with my UPS (connecting it to a car battery), and while it did function, it turned off after a few minutes because it was overheating. I added heat sinks to all the components that seemed to be really hot and that bought me a few extra minutes, but it still didn't last that long. My UPS just wasn't built to be on for that much time, and you never know if this one was, either. Though, this looks like it doesn't do any inversion because the batteries are at the same voltage as what it's outputting, so maybe it wouldn't overheat and could run for a long time without any problems. You might want to call them up or send them an e-mail, or something. Though, you might not, because that might damage your chances of getting it replaced when it breaks
    May 2001
    Post
    Maybe the overheating was due to the fact that your alt puts out ~13.8V instead of the 12V required by the UPS? Would that be a problem? Does seem like a cool solution...looks like an ATX power connector on there too...200 Watt ATX DC-DC for ~$40 ...not too shabby. only problem is that shipping to the us is ~125
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    moahdib's Avatar
    Jul 2000
    Post
    I thought UPS put out 120VAC from a 12V battery or are you guys talking about a different UPS?
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    they are talking about something different (i thought that too, then I looked at it)
    Its actually a power supply with big batteries in it, so when the AC is cut it runs directly from the 12V batteries INSIDE the power supply--no inversion. but its HUGE
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    moahdib's Avatar
    Jul 2000
    Post
    well ok i got it now.... atx PSU + UPS together...
    for me is back to Jeff's mini DC-DC ATX seems the way to go.
    My TL CarPC ver2
