Sounds like a Double Pole, Double Throw (DP-DT) switch.
Basically it works like this:
| | Top
| | Middle
| | Bottom
The left and right sides of the pins are seperate, and are not connected together.
The switch flips between the middle pins and the top or bottom pins.
Sometimes you can have a Triple throw switch, where the switch stays in the middle, making it effectively an Off, not connecting to either set of poles.
The front panel switches on computers these days are single pole (1 pair), single throw, normally open, with momentary action.
Momentary switches are spring loaded, and you close the contacts by pressing the switch. When you release the switch, the contacts pop back open... hence, they're momentarily closed when used.
And holding a power switch for more than 3-5 seconds will force a hard power off, which is normal. Every system does this.
If you press it once for 1-2 seconds, the OS treats this as an ACPI Power Button press, and safely shuts down, suspends, or hibernates, depending on your power management settings.
LinkBack URL
About LinkBacks
