Results 1 to 7 of 7
Thread: Soundcard Questions
    May 2006
    Calgary, Alberta
    Soundcard Questions
    I've been using onboard sound for a year and it sucks the big one. I'm looking at getting a right angle PCI adapter and using it to get a PCI sound card into my Ampie case. I've heard that the sound is better from an external USB sound card since it's away from the hard drive and fan and stuff but is it really noticeable? Am I not really taking a step forward in sound quality with a PCI card? I was told I should pick up an Audigy2 card so I might look into that, just wondering what your thoughts were.
    Or would I be better off just pre amping the signal to increase quality?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I wouldn't think it would make that much of a difference. I am using a external USB soundcard, but that is just because I used to run a laptop based setup (talk about crappy onboard audio). If your mobo has a pcmcia slot that you arent using, you might look at the pcmcia based audigy. I dont know too much about em, but it might be an option to get something that fits in your case.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    May 2006
    Calgary, Alberta
    Isn't it only laptops that have PCMCIA? Do you mean PCI?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by Maheriano View Post
    some minit-ITX boards also have a pcmcia, I don't know about mATX, but I would thonk there would be some boards that have them.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    _
    Mar 2004
    Little Elm, Texas
    MII series has a PCMCIA slot...if you go that route, use the Audigy 2 ZS, it's a really good card and has optical out if needed.
    Jan Bennett
    May 2006
    Calgary, Alberta
    So I found someone selling an Audigy 2 PCI card for $25 and I'm going to pick it up tonight. Should this suffice? Will the M1-ATX be able to power this, a PS2 keyboard, a GPS receiver, the touchscreen and the wireless network adapter? Is there such a thing as a right angle PCI adapter so it'll fit inside my Ampie case?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Oct 2004
    yes.. i have an audigy but i think im going to look for something with a little higher voltage.
    yes
    yes
    Fisher Customs
    www.fishercustoms.com
    AMD mobile Athlon 3200+, 512mb ram, M2-ATX, 8" dynamix 16:9, powermate, 80 gig hd, 802.11G PCI w/ stubby antenna, SB Live Soundcard, hardwired into stock Bose system
  1. soundcard to amplifier questions
    By tooby in forum Car Audio
    Last Post: 09-01-2006, 10:10 AM
  2. Uh oh. No audio from my soundcard..
    By braidy in forum Car Audio
    Last Post: 02-05-2006, 12:59 PM
  3. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
