Results 1 to 9 of 9
Thread: Car Radio Antenna Adaptors
    Apr 2002
    Houston, TX
    Has anybody run across info on a place to learn about and/or get adapters for connecting the car antenna wire to something like a USB FM / TV tuner antenna jack (which is basically a cable TV wire connection)....
    Any ideas.... Thanks in advance
    Dec 1999
    Buena Park, CA
    Radio Shack used to have adapters that would convert the Motorola connector to a standard "F" connector.
    Jul 2002
    Boston, MA
    I may be wrong, but I think it was a FM/TV splitter.
    Can't remember the part # off hand, but will get it for youy if you can't find it...
    -Mario
    Jun 2002
    Da Frozen Tundra
    I made my own. Rat shack has the connectors to adapt the standard size antenna to the mini plugs that GM uses, so I just cut that up, opened up a coaxial cable and wired it up. Solder and tape and all ready to go in about 10 minutes. Works great. You can make it any length you want.
    ricko73@yahoo 1997 Blazer Dashpc Style!
    VIA EPIA-M 9000 Hauppauge WinTv (FM tuner), 256 MB, 40 GB HD
    Running Linux: Slackware 10.0, xmms, mplayer and Roadmap gps
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Quote Originally Posted by ricko73
    How do you actually wire something like this? You wire the middle wire to the center piece of the RCA connector and the wire that wraps around it to the outside of the RCA connector???
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    I am gonna need one of these too, but BMW's new ones are different than everyone's :-/ I'm going to have to buy a BMW -> motorola then motorola -> F
    May 2000
    Ft Gordon, GA
    i bought an antenna extension cable and cut it in half. the cable is standard coax cable so you can add any end you need. i added a standard twist on coax end (tv type) and it worked ok.
    "if everything is under control, you're not going fast enough!"
    Jul 2002
    Boston, MA
    Quote Originally Posted by gork
    I got the adapters for my VW at crutchfield they have a great selection
    Newbie MiniRX7's Avatar
    Aug 2003
    Toronto
    What happens if you have a dual diversity antenna?
    I have a dual diversity antenna in my maxima and i use an adapter for my Kenwood MP3 deck, and the reception is crap, i was thinking maybe i could split it so taht one goes to FM one goes to TV..
    ED
    2k3 Max SE 6spd
    Temp setup:
    7" indash screen/Xbox running XBMC
    Carputer coming soon
    My 2003 Maxima
