1) stock wires are fine for switching the relay, takes very little power to switch a relay
2) yes
3) fuse size is relative to the size of wire used, although I'm not much of an expert here, 1 amp should be fine for the switched rem wire, since it only takes like 200ma to switch the relay
LinkBack URL
About LinkBacks
