Regardless of your setup noise is usually caused by the same thing.
First: Tape adapters are not that greatI am currently using one too, so I am not knocking you, but sound quality from tape adapters is rather poor.
Second: Make sure EVERYTHING is grounded.
Third: The ground loop isolator can help, but since it will degrade sound quality you should try checking your grounds first.
LinkBack URL
About LinkBacks
