have relay switch the remote signal on.
power relay switch remote-in
so, if the switch is on, the pc will boot.
Many folks discuss the amount of time it takes their carputer to POST, and ways to get from power on to music playing more quickly. An idea I've had is to power the computer before you actually get in - or even to - the car.
My car has a keyless entry system, so when I'm about twenty feet from it, I can unlock the doors with a keyfob remote. I'd like to intercept that "keyfob unlock" signal and use it to start the computer.
I figure the alarm brain probably controls the keyless entry as well, but haven't yet determined where it is located in the car.
Has anyone done this before? Any suggestions or ideas?
I'm planning on using the power features in Win2k and the VIA MOBO's bios to put the computer in hibernate mode when power is lost. So then when I start the car and by the time I get my seatbelt on the computer will be on and ready to go.
Don't know if this helps with your question?...
Greg
depending on the alarm, it may have a wire for an aux button, or - out on disarm or some other feature that you may be able to use for what you're trying to do.
I really cant believe people use Win2k in car PCs!
Do you realise that probably 90% of the bootup time for Win2k is stuff that you dont need in your car?
I have a Linux machine (P100Mhz, 32mb) which boots in what feels like 4 seconds! Ive removed everything unneccessary - It has no network, floppy, cdrom, parport etc support.
Its not yet in my car but Id estimate that it boots quicker than it takes to get myself sat down and belted with the engine started.
Far more suitable for a car PC.
I like Win2k... It's what your comfortable with and is why I'm using Win2k. I've disabled all non-essential services and drivers and start only the things that I need. From hibernate mode to functioning takes less than 30 seconds.
So by the time I start the car and buckle up my gps has already got a lock on 12 satellites and is ready to track. I'm cool with that.
Greg
I think what you will find is that not many people know linux well enough to have everything they want on it. And Personaly I'm not really excited about taking the time to learn everything just so I can't have Copilot 2002 in my car.
sv24, 733mhz celeron, 80gig hd, 5.6" MA Audio tft, x10 remote, RF Keyboard.
The alarm and keyless entry system are OEM, so it won't be as easy as interfacing with a Cobra's AUX output. As I said, I haven't even figured out where it's physically located yet!
As far as the OS is concerned, Linux is clearly superior with respect to stability and speed. It lacks much of the functionality of Windows, however, particularly from the standpoint of the developer. Using Windows, there are vast quantities of free components and code snippets, speech input and output APIs, and ActiveX interfaces to all sorts of stuff. Perhaps one day I will be knowledgable enough about Linux and ambitous enough to undertake the herculean programming task... for now, though, I'm well-matched with Windows 98 Lite.
you can tap into the door lock (the pulse is usually only 1-2 sec)but you will want to be able to deactivate this with a switch or relay that is open when the car is running so you don't trip the computer if you hit the unlock button in the car,
also the way you connect this depends on how the locks are triggered
trigger -lock +unlock
trigger +lock -unlock
reverse polarity for lock or unlock
If you come out talking sh1t don't try to turn around and wipe you azz.
Ok, here's what I can offer you..Originally posted by 00CericaRuss
From this web site click here
you can read on how he removed the progressive feature to where both doors open up on one push of the button. This leaves the push push feature open for what ever you may need it for. The link is for a GM 98 Z28.//
