Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Need three serial ports on VIA Epia - OK?
  1. #11
    Jun 2002
    UK
    Don't know if this helps , but my usb>serial adaptor came up as com 5. Com 1+2 are onboard.
    I tried a nmea gps module on the adaptor but windows / autoroute 97 did not find it. (in the end I used the adaptor for the ir reciver I built).
    VB6 Pro had no problems with the adaptor.
    I don't think there are limits on the number of usb serial ports as they are a sort of 'software' port that requires no more irq's than the usb port uses.
    (I may be wrong) <GRIN>
  2. #12
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Doesn't you epia via have a header for com port 2? Because mine does. and mine also has an IR port on it.
    Windows xp supports alot of USB Com ports, like 8 or more. not sure about 98 or 2000.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  3. #13
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by hardware_dave
    That's correct. They will all use the USB IRQ, and the limit is 256 devices under XP. The 4 or 8-port devices would use less resources, but they are usually a bit pricey. The only down side to these is some don't fully emulate a serial port. The data pins work, but the logic signals are non-functional (DTR, RTS, CTS, RING...) so if something needs power or only uses hardware flow control, it won't work.
  4. #14
    Elsewhere
    Quote Originally Posted by pRoFiT
    Your information is correct, but why are you resurracting 3 year-old threads to add nothing new?
    How about the Wiki?
  5. #15
    Apr 2002
    Houston, TX
    Quote Originally Posted by DarquePervert
    Okay, how about I resurrect a 3 month old post to a 3 year old thread.....
    I found this link through a of the forum and all the links are dead... that is not good, cause the links where solutions to adding more Serial (com ports) to a motherboard.... And that is what I need...
    So my question... I alreay have COM1 (the DB9 connection on the back panel) and COM2 (on the mother board) used... I need two more Serial Ports?
    Anyway to do this? Do Serial to USB adapter work backwards? I doubt it.....
    EDIT....
    I don't want anything like this... way to big... and actually I already have 2 of them...
    http://catalog.belkin.com/IWCatProdu...oduct_Id=20938
  6. #16
    Elsewhere
    Work backwards? That makes no sense, but whatever.
    There are smaller USB-Serial adapters out there. Check at your local computer shop.
    How about the Wiki?
  7. #17
    Constant Bitrate luper's Avatar
    Nov 2005
    North Carolina
    on my laptop i am testing my Rikaline 6010 gps receiver and its screwing up...
    I installed drivers.. fine... i plug the thing in (or when dirvers are done basically) and it goes to Blue screen..... Worker_thread_returned_at_BAD_IRQL... blah blah
    i think its conflicting with something.. it says its on COM4 port... i have usb thing for my smartphone and BT (althoguht it screwed up too!).. any suggestions.../
    ALMOST DONE!
    I got LCD, mobo, hdd, GPS h/s, most of wiring
    ALL i need is some stuff and then misc stuff: (offers?)
    PSU, more wires, slim cd/dvd drive, OBDII stuff, wireless adaptor, audio stuff, stuff period.
