Results 1 to 5 of 5
Thread: firewirebridge with imac dvd?
    May 2000
    Ft Gordon, GA
    does anyone have a firewire bridge working with the imac slotload dvd drives? thanks,
    Etrik
    "if everything is under control, you're not going fast enough!"
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    thought id revive this old post as im interested too...
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    it's a bit convoluted, but they're all just IDE devices on a firewire bridge... here's how it's basically going to have to fit:
    firewirecable -> firewire bridge -> IDE cable (1-device) -> imac DVD convertor board -> imac DVD drive.
    And if the firewire bridge has a female connector on it instead of male, just don't use the IDE cable.
    I've hooked up a laptop IDE CD-ROM drive to a USB2.0 board with the same method. It worked fine.
    May 2001
    Atlanta
    Quote Originally Posted by CrazyLittle
    Have any of you gotten this to work? I have an internal IDE -> firewire converter (which is just the board) with oxford911 chipset but can't get it to work at all. I've tried just about everything too (firmware upgrade, firmware options, xp & 98se & panther) any help is appreciated..
    thanks
    jason
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I got this to work with an external drive kit. Not the cheapest route, but I tore apart the external drive case for the board and it worked. As far as chipsets... well you should know me better than to even ask. If you could tell me where to look or what to look for I might be able to tell ya.
