Results 1 to 2 of 2
Thread: Harddrive problems (booting)
    May 2007
    Hi there, this is the first post i make but i'am reading this forum for quite a while now.
    I'm building my carputer now and i got it all in test phase.
    But now problems arrive; I got a brand new Maxtor 250GB on my Via-Epia V motherboard.
    When i got it running there are no problems, but when i reboot a couple of times my HD won't spin-up; i made a sound clip of what it sounds:
    www.deurbel.net/files/02_MOV00034.mp3
    when i let it 'cool off' and then boot, there are no problems and it spins right up.
    Is this a broken drive or do i need a better power supply?
    I'm asking this because when i was setting up windows i also got a old 12speed cd-rom hooked on. when the cd-drive was spinning my pc reseted itself so i discovered it was because the old drive; with a new 52X speed there where no problems...(old drives use more power)
    sorry for my bad English
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Will the power supply spin up a different drive? (yes may indicate the maxtor is bad)
    Will the Maxtor work on a different system with the same multi-reboot scenario? (yes indicates the drive is likely good)
    based on the results of the questions: Ask Maxtor for an RMA (Return Material Authorization), describe the issue to them.
    TruckinMP3
    Read the FAQ!
  1. Replies: 4
    Last Post: 12-27-2006, 04:22 PM
  2. Freezing and booting problems! 2nd Day of Install!
    By 2k1Toaster in forum Power Supplies
    Last Post: 06-01-2006, 02:08 PM
  3. Problems with USB CD Boot
    By bad-at-this in forum WinNT Based
    Last Post: 03-10-2006, 06:41 AM
  4. Problems booting from CF card
    By dcdc in forum Operating System Optimization
    Last Post: 01-16-2006, 07:10 PM
  5. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 02:08 PM
