Results 1 to 7 of 7
Thread: IDE adapter: 40F -> 44M
    May 2007
    Sterling, VA
    I checked out the whole ebay and did not come up with anything.
    I am looking for the ide adapter 40F - 44M, but everybody offers 40M - 44F. Do you know where I can find the one I am looking for?
    Thanks,
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Sorry, I don't know of a reverse one. Why do you need something like this? Maybe a solution can be found with cabling?
    May 2007
    Sterling, VA
    Both mobo and hdd uses 44pin and I need to connect the slim cd to the whole set. Maybe there is a 50 PIN JAE CD/DVD-Rom to 44-pin IDE adapter?
    Jun 2005
    Oakland, CA
    Ah, I see. Well, try these:
    slim cd to 44pin:
    http://www.mini-box.com/Slim-Cd-ROM-...er?category=18
    IDE cable connecting a 44pin and a 40pin to a 40pin on the mobo:
    http://www.logicsupply.com/product_i...roducts_id/123
    btw, a 44pin cable is, at best, ATA33, which means you might not be able to get the bandwidth you need if it's a DVDROM
    May 2007
    Sterling, VA
    Quote Originally Posted by psyrex View Post
    That's what I was looking for... Thanks.
    hmmm... how about usb 2.0 (which I would like to avoid) or sata?
    Jun 2005
    Oakland, CA
    Both of that should work. I too didn't want anymore USB and settled with firewire for the DVDROM.
    BTW, I did a quick search for sata, and this is the only one I found for 10 seconds of searching:
    http://dfwdepot.com/dvd-ram/index.ph...roducts_id=147
    it's kinda big.
    Mar 2002
    Quote Originally Posted by maloosheck View Post
    Just FYI, you could plug a 40M - 44F adapter into the motherboard, get another 40M - 44F adapter to plug into the HD, and then use a 40-pin cable. I've done this before, and the adapters do work 'backwards'.
    What do you mean? ATA33 is more than suffient for DVD playback. I think even DVD burning can be done at a fair speed, so long as you have DMA enabled.
  1. USB -to- IDE Adapter $11.99 SHIPPED - Meritline.com
    By we87 in forum General Hardware Discussion
    Last Post: 05-10-2007, 11:02 PM
  2. San Disk & IDE adapter
    By Cross_ in forum General Hardware Discussion
    Last Post: 04-26-2007, 01:55 AM
  3. IDE to USB adapter & Hibernation problem
    By nkotch in forum General Hardware Discussion
    Last Post: 03-15-2006, 05:55 PM
  4. Slimline DVD + IDE adapter + IDE -> USB adapter = no drive in Windows?
    By WiCKeD 5.9L in forum General Hardware Discussion
    Last Post: 08-04-2005, 10:49 PM
  5. Slimline DVD > IDE > USB Has anyone tried this?
    By Keebortz in forum General Hardware Discussion
    Last Post: 07-11-2005, 04:21 PM
