Results 1 to 3 of 3
Thread: Primary IDE channel no 80 conductor cable installed?
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    When I boot up and the PC detects my hard drive I get the following error / warning:
    "Primary IDE channel no 80 conductor cable installed"
    I am using a 2.5" laptop drive (Toshiba 60GB 5400/16MB 2.5" Mobile PATA HD), M10000 Motherboard, and a laptop->IDE adapter (http://www.tigerdirect.com/applicati...Sku=C184-17705)
    I have also recently began to experience frequent, unexpected shutdowns of the computer. I want to know if this message is related to my shutdowns.
    I am pretty sure I never received this 80 conductor cable warning in the past.
    My question:
    Could this be faulty hardware? If so, would it be the HD, Mobo, or IDE cable?
    I plan to run two tests when I get home:
    1) Try a different hard drive to see if the error appears
    2) Try a different IDE cable
    Any other tests I should run?
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    That's just a cable thing. Use a 80 conductor 40 pin cable. You're probably using a 40 conductor 40 pin cable right now. Frequent shutdowns are likely power related, and not this.
    Sep 2005
    Seattle, WA
    So I swapped IDE cables and the 80 conductor warning went away
    I then put the old IDE cable back on and the message did not appear. This makes me even more confident that this message did in fact recently start appearing.
    Booting the PC w/o the message, I allowed the PC to run for 2+ hours. Previously I was seeing the unexpected reboots & shutdown.
    B Smoov
  1. RE: Who Wants Custom Length 80 Pin IDE cables
    By 047025n in forum General Hardware Discussion
    Last Post: 02-23-2004, 03:25 PM
  2. Where can I get 80 pin IDE cable?
    By jtk in forum General Hardware Discussion
    Last Post: 01-27-2003, 03:29 AM
  3. FS: 15' feet of 80 wire IDE cable. Great for DVD-ROM's.
    By LESLIEx317537 in forum Classified Archive
    Last Post: 01-27-2003, 12:53 AM
  4. 80 pin ide to 40 pin?
    By albysure in forum General Hardware Discussion
    Last Post: 01-07-2003, 06:49 AM
  5. Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!)
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-14-2002, 05:05 PM
