just flip it and make sure the ribbon cable does not get tamper with the power supply and you should be find. also dont get a cable that is too long.
6" should be fine
I have the VoomPC/Ampie case, an M1-ATX PS, and a M10000 motherboard.
My issue is I that I believe my IDE cable was damaged due to the way it was routed (twisted / turned/ squeezed) to the motherboard.
The reason I found it so difficult to route the cable is because the hard drive sits under the power supply, which sits on two stand offs. Not only is the PS like a 1mm above the hard drive, but the standoff also gets in the way.
Does anyone have any pics / suggestions on how to route my IDE cable in this configuration?
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
6" should be fine
flip it? I dont get what you're saying
B Smoov
