What do you mean "the power supply starts up"? Do you mean the motherboard starts the boot process?
If that's the case, you should go into the BIOS setup and see if there is an option to startup after power failure or something. Some BIOSes will have that feature, and if it's enabled, it would explain the off behavior.
I think the Opus would also have to be set into dumb mode for this, but I'mnot 100% certain on that.
LinkBack URL
About LinkBacks
really appreciate it mate
