Results 1 to 4 of 4
Thread: Disk space required for minimum XP install
    May 2007
    South Africa
    Newby here... Hi all!
    Having installed a DIY Engine management system (megasquirt) into two of my cars I now wish to add a car PC so I don't have to cart my laptop PC to the car when I want to fiddle with settings.
    Here's the catch:
    I want to avoid using a hard disk preferring to rather use a flash disk(s) of sorts. Reason: SEVERLY corrugated an potholed roads at the "£$% end of Africa. I just can not see a hard disk surviving this no matter how good.
    What is the smallest amount of disk space required for a really small (but functional ) XP installation? (I have no other applications in mind)
    Regards
    jagwit
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    if you try running the install, from what i can remember, it tells you how much space is needed for full and minimum installations of the OS.
    '08 VW Rabbit S 2.5
    Carputer Progress:
    Design:[][][][][][][][][][][][][][][][][][] 100%
    Fabrication:[][][][][][][][][][][][][][][][][][]100%
    Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
    In trouble...
    Mar 2007
    Lancaster Pennsylvania
    hi there.
    from my experience, a clean install will set you back around 1200 mb.
    but, if youre going for functionality, i would suggest doing a search for tinyXP. im using it as im typing this.. works great and the install was around 400 mb. also, search for nLite xp. you can build your own smaller version of XP to fit your needs.
    May 2007
    South Africa
    Quote Originally Posted by keatonreckard View Post
    hi there.
    Excellent!! Thanks!! Will have a look. This means that a 1Gig flash will most likely do the job.
    Kind regards
    jagwit
  1. Windows XP LAN Boot install – no floppy or CD-ROM
    By Zip-Lock in forum Software & Software Development
    Last Post: 10-20-2008, 01:29 AM
  2. Replies: 3
    Last Post: 12-23-2007, 08:39 AM
  3. smallest XP install?
    By W6-Ryan in forum General Hardware Discussion
    Last Post: 12-08-2003, 01:23 PM
  4. I've Nehemiah board but when I try to install Win2k or XP it crashes
    By bertybassett in forum General Hardware Discussion
    Last Post: 10-04-2003, 11:05 PM
  5. XP sleak install
    By Bj in forum Software & Software Development
    Last Post: 09-02-2003, 07:29 PM
