Results 1 to 10 of 16
Thread: PC freezes on boot when USB HD connected
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    After some googling and getting many anwers about booting from an external HD wich I don't need, I will post my question here:
    When my external USB HD (2,5" Samsung) is connected, the computer freezes often when booting. Where normaly the memcheck is performed it just does nothing anymore. Sometimes removing the power from the PC and putting it back on solves the problem but not always. Also on one occation after about 10 minutes suddenly the PC starts. I don't always have this problem but I do have it most of the time. When the disk is not connected, I never have issues. Any Ideas?
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
    Nov 2006
    Gloucestershire, UK
    Check your bios settings, and make sure that the first booting device is your o/s hd.
    Sep 2006
    Belgium
    This setting is correct. O/S disk is the first and the only boot device.
    DIGItonium
    Guest
    Looks like a weak 5V rail. I notice you have a couple of hard disks in your system. Consider upgrading to something more than M1-ATX?
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    All 3 of the Epia boards that I have had did this if you had anything that Windows would load as a disk drive plugged in to USB, either in a hub or straight into MB. It did it for thumb drives. card readers, and USB cd roms. I know this does not fix your problem but the only fix I found was replacing the MB and make sure it is not a Via. Sorry for your troubles.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Mar 2006
    Montreal
    disable USB Legacy support option in bios, your problems should be solved.
    Sep 2006
    Belgium
    The first thing I will do is disabeling the USB legacy support in the Bios. Seems like the simplest sollution.
    If that doesn't work I will try using the 220V home adapter that was with the disk to power it. This should take the load of the 5V rail. If this helps I could fabricate an inverter to power it directly from the car battery.
    If these sollutions both don't work I think I have a problem. Don't like the idea that I will have to change my MB...
    I will keep you guys updated on what happens. Thanks
    Sep 2006
    Belgium
    Option one: no luck... I don't seem to have an USB legacy support option in my bios so I can't disable it.
    This weekend I'm gonna try the second one. Powering the HD externaly.
    May 2006
    Calgary, Alberta
    I have the same problem. If I try to boot with my memory stick in the USB port, it freezes on boot up. I have to plug it in after booting.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Montreal
    Maybe it's because mine uses an A8V-VM motherboard, which, by standards, have those standard bios options, dunno about you epia users hehe
  1. USB device to allow for fast boot up?
    By fatejd in forum General Hardware Discussion
    Last Post: 01-20-2007, 04:48 PM
  2. Turn the pc on from the boot
    By NiN^_^NiN in forum General Hardware Discussion
    Last Post: 08-06-2005, 12:42 AM
  3. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  4. Converted 3.5" HD to External USB
    By PaCMaYNE in forum General Hardware Discussion
    Last Post: 01-09-2005, 05:55 PM
  5. Replies: 5
    Last Post: 01-03-2005, 09:39 PM
