Results 1 to 3 of 3
Thread: Infill G4 steering wheel control
    Apr 2007
    Moscow, Russia
    cartft.com published some info on how G4 steering wheel interface works and a software utility to tune the G4 interface to your particular car. It's supposed to work with any resistive-ladder type controls - the software prompts you to press the steering wheel buttons one by one, measures the resistance and stores it for future matching. Most of the program interface seems to be in Korean, but it's pretty intuitive
    Seems to work ok with InfillStation software, as far as I can see touching the wires with different resistors while G4 is still sitting on my desk at home
    The hardware part (ADC?) seems to be connected via USB, because when you run the utility on a normal PC (not G4) it complains in Korean but the letters USB are clearly present in the message
    http://www.cartft.com/support/drivers/Infill-G4
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    We've been playing with the Steering Wheel utility too, but we haven't found it to be very practical or a way to support it for any of the cars we have tried on.
    When you start the utility, it will show lots of stuff in korean. Once you click the "AUTO SCAN" button to start programming it, it will flash a message 6 different times for the 6 different possible buttons. Each time the message flashes, you want to hold down a different button on your steering wheel controls and it should set some hex letters in the text box. After going through all 6 different buttons, the values in the 6 text boxes should have different hex values in them. You should hit the Send command once you are done and this will program the hardware to remember the values of your different steering wheel controls.
    Exit the program, now when you press any of the steering wheel controls, it should send a different key combination to windows. This key combination can be used in StreetDeck or any other program if you can program the keys for it.
    Now all this that I just said basically assumes you have your can hooked up properly to the remote control wire on the G4. Unfortunatly, and this is the reason why we haven't released or support this utility on MP3Car, there is no standard for resistive steering wheel controls. Some cars use multiple wires, some reverse ground and power, some use the CAN bus which totally won't work. On most cars, to hook it up, you will probably have to add additional resistors. I have only gotten 2 of the 6 buttons working in my car and I’m doubtful there is anyway to get it working better with the one wire on the G4. Those 2 buttons work real well, but that’s bout it. If you really want steering wheel controls to work with the G4, you should just get an SWI-X, it works with the IR sensor on the G4 and has very good and well documented support for most cars.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by Marassa View Post
    cartft.com published some info on how G4 steering wheel interface works ...
    The link seems to no longer work, you wouldn't happen to still have access to it (hard copy, .pdf, etc?) I have an 07 Saturn (GM) that I want to hard wiring without an IR adapter.
  1. Steering Wheel Controls
    By speakers_86 in forum Input Devices
    Last Post: 04-10-2007, 11:35 PM
  2. Audy A8 Steering Wheel Control to PC
    By k11SiC6 in forum Input Devices
    Last Post: 03-02-2007, 05:54 PM
  3. A6 steering wheel controls
    By blueglitch in forum Input Devices
    Last Post: 02-14-2007, 09:10 AM
  4. Steering Wheel Control
    By Micv in forum Hardware Development
    Last Post: 07-13-2005, 12:45 PM
  5. Wireless control for steering wheel
    By DodgeCummins in forum General MP3Car Discussion
    Last Post: 02-15-2002, 02:14 PM
