Results 1 to 10 of 15
Thread: Delco Head Unit Inputs.
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Today I finally got around to hacking my head unit to have audio inputs. I've had the parts for about 12+ months (I'm not lazy, just busy) Once you have the parts and figure out how to take apart your dash. Then the job is a simple as just pluging a cable into the aux port of the head unit after a little bit of soldering. Info is up on my site. Look under "System" then go to "Audio".
    You will have to aquire a remote tape/cd deck. You can buy them new or at a junk yard. Pin-outs are on the site, for anybody who would like to hack it future. Aka fake the remote connection signal.
    The sound quailty is great. No hissing, buzzing, or alt whine.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Constant Bitrate jpainter99's Avatar
    Aug 2002
    Any idea which of the slave tape units have the right pinouts? I know where I can get a tape unit out of an 88 chevy pickup but I am not sure it will work on the Delco unit in my 2002 GMC pickup etc.
    Feb 2001
    To my knowledge the aux connecter (9 pins) has been used since the mid 90s.
    Somebody with a little more knowledge in electronics could capture the "connected" signal and fake it. But that is over my head.
    The most I can tell you is this. You can disconnect the remote unit after accessing it the first time. As long as the radio stays on, it thinks the remote unit is there. Even after switching back and forth from AM/FM/CD. I've read that the E&C is a serial line, but what method it uses I don't know.
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I'm very interested in this as well but I cannot seem to locate it on your webpage. Your system page does not fully load.
    Mar 2002
    I hacked the delco unit in my 99 cavalier the same way.
    I ran a custom 9 pin wire to the trunk were I installed the cassette deck. I also installed a switch which switches between cassette and my carputer which is installed near the stereo.
    Works great, no sound distortion.
    Nov 2002
    Buffalo, NY
    I have a 2000 Yukon, and a similar rigged setup. Leave it to GM to overcomplicate a tape deck by adding a serial bus to it.. It probably uses the same J1850 VPW protocol the rest of the car uses. To interface it (or your car) with your PC, the only thing around is an interface from www.vehicleinterface.com - too bad theres no software.
    If you have an older, pre-digital, analog car you are probably in luck.. this type of setup might work:
    http://home.hiwaay.net/~davida1/radio.htm
    ...as you can see, GM used the same 9-pin connector back in the 80's as they do now, but the pinouts are all different so be careful.
    Feb 2001
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
    Jul 2002
    Houston, TX
    Could i some how get an AUX input out of my Delco Pontiac Monsoon cd-player head unit?
    Hey ODYSSEY, how do you like that steering wheel remote? how invasive is it? is it possible to mount it in a more cosmettically appealing fashion, that you can see?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Originally posted by ODYSSEY
    Works for me
    http://www.mp3car.com/usersites/ODYS...ite/audio.html
    Yeah.. it's on the audio page, not the system page. Thanks though!
    Jul 2002
    Houston, TX
    so... all i want is a pair of RCA's coming out of the back of my head unit. clarity please, what do i need to go about doing?
