Results 1 to 8 of 8
Thread: Timer Settings Lilliput TC1000 Computer
    Jul 2006
    Virginia
    Hi all! My first post! Woot!
    I've been running this carputer for several months now and the only problem that I have is that the power controller on it hard shuts down the computer after about 12 seconds, but hibernate takes about 15 seconds.
    Is there a way to change the timer setting to take a bit longer for the power shutdown?
    There doesn't seem to be anything in the BIOS, so I'm hoping it's not hard wired. Can anyone think of any other solutions, like shunting power to the ACC lead from a capacitor or something?
    Any suggestions are appreciated.
    Oh, as a side note, does anyone know exactly the memory type that I can buy to upgrade to 1GB?
    Thanks again!
    Jan 2007
    TC1000 ram upgrade
    Hi
    You can use PC2700 1GB RAM ( 200 pin laptop ddr ram).
    regards Primo
    Jul 2006
    Virginia
    Actually, I just took my TC1000 apart and it was running a PC3200 DDR400 SODIMM (what a pain to remove, too!).
    Still looking to change setting or speed up Hibernate. Thanks.
    Jul 2006
    Virginia
    bump. Any ideas anyone?
    Jul 2006
    Virginia
    bump bump! Just got back from Iraq and still have no answer to this. Thanks!
    Low Bitrate gfmedia's Avatar
    Aug 2007
    Rochester, NY
    Quote Originally Posted by huhsler View Post
    would also like to know, I still haven't found an answer...welcome home
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    First off what type of Mobo and number 2, what power supply do you have? If its a M2-ATX there is a jumper on the PSU itself that you can set to how long it takes to hibernate or shut off the PC.... my OPUS 320 also has the feature. I am not sure on other PSUs'. If I am reading correct your PC is made by Lilliput, it may have a cr@ppy PSU to begin with. Maybe you should upgrade the PSU.
    PS: from what i have read, it has a 20 second delay feature......
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2006
    new york
    Does anyone knw where i could buy a Lilliput TC1000 case only?
  1. Lilliput TC1000 + GL702-TV/C/T combo
    By secured-nor1 in forum General Hardware Discussion
    Last Post: 06-23-2006, 12:46 AM
  2. Lilliput to Opus & time settings
    By nibix in forum Power Supplies
    Last Post: 06-29-2004, 11:44 PM
  3. How do you save Lilliput video settings?
    By ML430 in forum Input Devices
    Last Post: 06-10-2004, 12:37 AM
  4. Lilliput forgetting settings?
    By Magma in forum LCD/Display
    Last Post: 04-21-2004, 10:52 AM
  5. Lilliput vga settings
    By junior in forum LCD/Display
    Last Post: 10-27-2003, 05:25 PM
