Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: audio interface question
  1. #11
    Jun 2001
    Washington State
    Post
    sweet, is that specifically for the alpine units, or are there adapters for most of the major manufacturers? thanks!
  2. #12
    Jul 2001
    Post
    If you are looking for good car audio equipment and not to expensive look at www.sounddomain.com and www.soundcity.com. I have not bought anything from soundcity but have from sounddomain and I really like them. I got my head unit for around half the retail price. I am having the same problem that you are having also. I just bought a new head unit not more than a year ago.
  3. #13
    Jun 2002
    Central Illinois
    You dont' need the $80 adapter unless you are using a CD Changer, too... Without the Changer, there is a $15 adapter (KCA-121B) that will only work if you have the audio mute function available on your head unit. Check out this post for more info:
    Alpine AiNet aux input adapter SOLUTION!!!
    - Aaron
  4. #14
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    this is what you need to add your carputer to your system when you don't have an aux input on your head unit
    http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-806
  5. #15
    Jun 2002
    Central Illinois
    Yeah, the line-level switch is a good cheap solution... The only drawback is that now you have to control volume for your head unit, and a seperate volume for the mp3s. Getting an input into the head unit is ideal since you can use it to control everything (plus you can use its EQ if available, etc...). Plus, some people don't have amps in the car and are just using the HU's power to drive the speakers...
    - Aaron
  6. #16
    Dec 2000
    pittsfield, ma.
    well maybe how about running your hu through the carputer at the line level input?
  7. #17
    Jun 2002
    Central Illinois
    Yeah thats an interesting way to do it... Won't work for me, though, I have a line out and a subwoofer out from my HU... I like to be able to control the sub level from the HU.
    - Aaron
