Do you have a source for these?
Ivan
http://www.tcommate.com.tw/EN/INFORM...78/P4BGA_E.htm
Here are the specs, only 2 inches longer than FV24 but doesnt have video out.
1. CPU
Supports Intel Pentium 4 1.3GHz ~ 2.4+GHz CPU with 400/533 Mhz FSB frequency
Supports 478 FCPGA2 pin-package P4
2. Chipset
Intel 82845G & ICH4
3. Main Memory:
2x184 pin DDR SDRAM DIMMs to support up to 2.0GB DDR SDRAM
3. Slots:
1 AGP (4X), 1 PCI slots, 1Riser Card (Option)
4. IDE:
Support two IDE channels & up to four IDE drivers
Support gUltra DMA 33/66/100h transfers up to 33/66/100MB/s
5. VGA:
Built in Intel SVGA Controller with 3D engine
6. Audio:
ACf97 Realtek 201A audio CODEC on board
7. LAN:
Support 10/100Mb full duplex LAN
Intel Pro/100 Fast Ethernet on board
8. USB
Support 4 USB ports (Rev.2.0)
9. IEEE 1394 Interface
VIA IEEE 1394 Controller with internal 1394 connector
10. I/O:
1 Floppy connector
1 Printer port
2 Serial ports
1 SIR connector
1 PS2 Keyboard connector (mini Din)
1 PS2 Mouse Connector (Mini Din)
1 game/midi port
1 line in
1 speaker out
1 microphone in
11. Power management:
ACPI & APM
Ring Remote wake up
RTC alarm
Software shutdown
Auto fan on & off
Power button
Wake on LAN ready
12. Award flash BIOS
Support ACPI function
Support NCR SCSI BIOS
Support Green & Soft-off function
Support LS120 Boot Up
Support Multiple Boot Up
13. Form factor:
Mini Flex-ATX form factor
17.0x 24.5 cm2
Ordering Option:
P4BGA: Mini-FlexATX mPGA478 Pentium 4 DDR
Motherboard with VGA, LAN, Audio,
IEEE 1394 and USB 2.0 Interfaces
(1 x AGP and 1 x PCI Expansive Riser Card
in Packing)
P4BGAP: Same as P4BGA but with 400 MHz FSB and
without AGP Interface
(2 x PCI Expansive Riser Card in Packing)
Ivan
Ah, but its missing the one critical component if you want to use a composite lcd. There are a lot of similar boards out there, all having the same "flaw."
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
can_crusher
What do you mean by source?
MP3DUB
Can you kindly show me the links to a lot of other simular "boards" not barebones besides the shuttle ones?
The shuttle FV50 has only PCI slots and no USB2.0 but it does have S-Video out and 6ch audio out. I still havent seen a small LCD with S-Video in. I've heard a lot of people have problems with S-Video to composit video adaptor like it only show black and white or the color doesnt look right. Also doesnt the 845G have better 3d graphics than the SIS 650 and 651 video chips?
This board came out before the SS51 barebone was available.
The only other board that has all the features is the SS51, but its only available as barebone.
believe me, I would rather have the motherboard in the SS51 but its not available only as the motherboard
As for video out, you can buy a small scan converter for less than $50 that lets you adjust the size and position of the screen, unlike the built in video outs on the FV24, FV25, FV50 and the SS51. I know for a fact that people complaint about the black borders around the edge of the TV screen cuz I have the FV24 and no matter what I do, I cant get rid of the thick black border on the edge of the TV.
Do you know where you can buy one of these and for how much?
Ivan
Off hand, I can't give any examples, but when I was searching for a new matx socket a board the other month, I kept coming up with all sorts of p4 boards that fit my requirements, but had a hard time finding a socket a board with everything that I needed. But if you search around, you're bound to run into them.
-Nick
Sapphire just released newer versions on the ATi IGP with ATi's south bridge. USB 2.0, 6 channel audio, blah, blah, blah...
http://www.sapphiretech.com/PRODUCT/PRODUCT-board.HTM
A3-M293 AMD
A4-M280 Intel
Search newegg.com for "sapphire a3" for the older version with USB v1, AC97 audio and vga/composite out for $72.
I'm going to see if the new distributor can get those to my old boss.
-Mario
90% Done
60W DC-DC & shutdown controller
Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
All in a shiny White 2000 V6 Mustang
Click here to visit my NEW PhotoAlbum
I wonder how long it will take Shuttle to utilize the new mini-itx platform with the Appolo CLE266 with a ziff socket so I can stick my PIII Tulatin 1.26GHz 512K Cache CPU in...
-Mario
I dont know about you guys, but to me, my P3 933Mhz on the FV24 seems really slow compare to my P3 1Ghz home computer that I used to have. I think it's a chipset problem. The 1Ghz was a 440BX chipset. It's almost as fast as my P4 2Ghz running app. There is always hourglass when I switch apps like from Winamp to GPS or from GPS to OBD-II info on my car PC.
