OK. Here is the definitive response. This board does support both stand by and hibernation. However, before it will, you have to have hibernation enabled by
software setting (in XP anyway). Under Display Properties | Screen Saver | Monitor
Power | Power (button) | Hibernate | select Enable hibernation. Then from the front end of your choosing, assuming it supports it, it should work.
My test auto loading Centrafuse I have the following times, but YMMV:
Cold boot to FE - 52 seconds
Hibernate to FE - 27 seconds
Stand by to FE - 4 seconds
This is running under XP Pro, w/ the D201GLY, 1 Gig mem, BU-353, Shark 8" TS, and some POS power supply. And that's all I have to say about that.
