Page 13 of 30 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 298
Thread: Intel MINI-ITX board - D201GLYL & D201GLY
  1. #121
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by MMZonker View Post
    That's the recommended setting for the m2-atx when you have the jumpers right. As I understand it, after 2 hrs, it's a total shutdown of the power rails when jumper B is set. You can probably just come out of hibernate before 2hrs. If all the jumpers are removed, it's a standard PSU. how do you have it setup?
    thats the way I have it set up. The M2-ATX doesn't do ether standby or hibernation, that is set in the OS, which WMPWI explained. The M2-ATX simply presses the computers power button. Then the computer will either go into hibernation,standby, shutdown,ask me what to do, or Do Nothing. depending on what you have selected under Power Options Properties/Advanced/When I Press The Power Button On My Computer:. I never thought to change that from Hibernation, which I used with a inverter/PSU, to standby. I'll have to give it a try and see what happens.
    The 2 hour shutdown does not effect hibernation since the computer shuts down once it's in hibernation. It will effect standby, I'm assuming it completely shuts down the computer and you would reboot cold.
  2. #122
    Nov 2005
    Quote Originally Posted by upspace View Post
    the same here as posted previously. its a fantastic board for a car pc but having the bios post screen staying for 30-40 secs alone it takes ages to boot or de-hibernate (de-hibernate only takes 10 secs for 1 gb ram for me).
    what is the trick with the bios to make post faster? bios upgrade (doubt), hardware issue (1gb ram check - how to disable, set to fast mode), 21/2 inch harddisk...
    or is it the usb hub with 9 usb devices attached (gps mouse, wifi, dvb-t, touchscreen, usb keyboard, etc.) that tries to boot/recognize proprietary usb devices.
    the bios splash screen now only stays about 7-10 secs by disable usb legacy drivers in the BIOS settings.
    that is the bios tries not to load all the usb devices attached on my car pc (dvb-t, wlan, gps mouse, carnetx psu monitor, touchscreen, keyboard, dvd drive, external usb disk...) which are not of use at boot time anyhow.
    disadvantage i cannot use the usb keyboard to change bios settings but have to connect a "normal" ps/2 which is fine since you are doing this only one or two times.
    hope this helps others too to bring boot time down.
  3. #123
    Low Bitrate wmpwi's Avatar
    Sep 2007
    Western Michigan
    Now that the discussion is getting further in to power supplies, has anyone run this board in the Morex 5677 Mini-ITX case, as in this with the included power supply? It seems that the mother board requires one of those 12 V processor core voltage connector (2 x 2) type plugs which the power supply that comes with the case does not have. Do I have to get a different wiring harness or am I stuck with having to get a whole new power supply? (this is the part were my electronic illiteracy starts beaming through). Thanks
    Charley
    A computer lets you make more mistakes faster than any invention in human history
    - with the possible exceptions of handguns and tequila.
  4. #124
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    I thought the opus had the 4pin plug on it. I'm probably wrong though, I've really only looked at the M2 since that's what I have. But you're right, you can use any ATX power supply that includes the 4 pin P4 plug on it. Most boards that have that plug will meet the current requirements on the 12V rail.
    Is it that it's fun? Or that it lets you forget yourself?
  5. #125
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by wmpwi View Post
    Charley
    Looks like your power supply only supports 60W, dont think it would be powerful enough. The 12v P4 connector can be hooked up with a cable that connects to one of your 4pin molex connectors that powers your hard drive etc.
    The connector that you buy is not the best solution, but the only solution. Basically it supports only 5A on the 12v rail as that is what standard ATX power supplies needed to support back in the day. The P4 connector was designed to push 8A. So this solution is not recommended by Intel.
    If yours is only 60w your 12v rail(s) will be really low.
    Sound Stage
    Eclipse|MTX|Infinity
  6. #126
    Constant Bitrate Homebrew's Avatar
    Maryland
    For everyone's reference, I'm currently using this board with a morex t3310 case, though i'm using it for a home router/firewall not as a carpc. This case has a 60w PSU and also is missing the P4 connector. It took quite a bit of work to get this setup running in this case, so I don't recommend the combination, but so far it's been up for about a week and I haven't had any problems. Not to say that problems won't develop, as I realize a week isn't very long. I realize this isn't up to intel's specs, but just wanted to throw it out there that I'm another person running this board on a low power PSU and molex to P4 converter. Granted I'm using a lot less devices than most of you would be using. I'm only running a 5400rpm laptop HDD and a 10/100 nic in the pci slot. No additional fans, no CD/DVD drive, and no usb devices except when I hook a keyboard and mouse to it when local administration is absolutley necessary. It may be that I'm able to get away with this PSU setup simply because I'm running so little off of it. It can be done obviously, but people should prepared that problems could crop up using such a PSU setup. My setup is nowhere close to being proper, but so far it does function as it should. I gotta say though, I do have my doubts about the longevity of the PSU. If I were gonna use this as a carpc, I would definetly run a better PSU. Just my $.02.
    For the guy asking about heatsink options, you can look at heatsinks designed for northbridge chips as many of these use the same style retaining clip. Be VERY careful if you decide to do this since this is an application those heatsinks weren't designed for. With that said, I think if you get an all copper heatsink of equal or larger size, you'll be alright. I'm currently looking at this heatsink:
    http://www.sidewindercomputers.com/minoxewh.html
    Because of my case, I can't get a heatsink that is more than a few mm taller than stock. This fits that requirement. Also it says it can be used on pentium-m chips so that makes me feel a little safer as well. The drawback is that it doesn't use the style retaining clip thats on the board. However I think it could be easily adapted to do so. You could also replace the stock thermal pad with some Arctic silver(I've already done this) if you wan't some added cooling but don't wish to change the heatsink.
    -Kevin
  7. #127
    Sep 2007
    Western Michigan
    D201GLY & Morex Cubid 5677
    Keven, Thank you. An informed response. While not what I wanted to hear, it was what I needed to know. I'm a little disappointed that the PS isn't workable since the people that sell these (the mother board as well as the case) imply something like "The Morex Cubid 5677 Mini ITX case is compatible with the motherboards we carry in the store." Maybe compatible with the boards, but apparently one can't assume that the accompanying power supply will work. I do like the case but, I'll have to buy another power supply. Hope you don't mind and occasional question during my build and thanks again for the input.
    C
    QUOTE=Homebrew;1133713]For everyone's reference, I'm currently using this board with a morex t3310 case, though i'm using it for a home router/firewall not as a carpc. This case has a 60w PSU and also is missing the P4 connector.<snip> change the heatsink.
    -Kevin[/QUOTE]
  8. #128
    Maryland
    No problem, just sharing my experience. You're mileage may vary. FYI, I believe Sonicxtacy02 is using the case you mentioned with this board, though I'm not sure he commented on the PSU. I also forgot to mention that not only am I using the molex to P4 adapter cable, but it's plugged into a molex Y splitter. The PSU only had one molex, to I had to split it to power the HDD and provide the P4 connection. I also had to use an ATX harness extension because of the location of the ATX Plug on the board. The t3310's motherboard cable was too short to reach. So as you can see my setup is far from ideal. I'm gonna keep running it though and see how things go.
    -Kevin
  9. #129
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Homebrew View Post
    -Kevin
    i never really tried to use that pos 60 watt included psu. I plugged it in with a molex/p4 converter.. tried to turn it on and the thing burned out for seemingly no apparent reason. I would advise anyone to try it else something worse could happen.
    Live mp3Car Facebook Chat
  10. #130
    Oct 2005
    Southern Indiana
    FWIW, i have one of these boards I used in a NES PC (in case you have been living under a rock, that is a PC stuffed into an old Nintendo.) I have it powered by a Pico-PSU thats rated for 120 watts, but using a power brick only rated for 60.
    http://www.newegg.com/Product/Produc...82E16813995001
    I have a laptop DVD burner, a laptop 30 gb HDD, an extra 60mm fan, all powered without problem
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 10:18 PM
  2. where can i get a mini ITX for cheap
    By D_roc in forum Newbie
    Last Post: 09-24-2007, 06:55 PM
  3. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
